Accomplish your productivity with an easy way to print from your smartphone or tablet. Fly through tasks with an all-in-one with fax, automatic document feeder, and wireless.
Affordable at-home printing
Save on ink and never run out. Print photos or documents for the same low price. Print up to twice as many pages or photos with HP ink cartridges. Get high-quality prints - time after time - with an all-in-one designed and built to be reliable. -
Easy printing from mobile devices
Easily print documents and photos from a variety of smartphones and tablets. Start printing and get connected quickly with easy setup from your smartphone, tablet, or PC. Connect your smartphone or tablet directly to your printer - and easily print without accessing a network. Print remotely without worries. The auto-deploying output tray keeps your pages from landing on the floor. -
Say hello to productivity
Take charge of your tasks with the easy-to-use 2.2-inch display - simply touch and go. Use the automatic document feeder to quickly tackle multi-page jobs. Automatic two-sided printing saves paper. Print borderless, lab-quality photos and laser-quality documents right in your home. -
Perfect for your home and home office
Save your space with a sleek all-in-one designed to fit where you need it. Print in any room you choose without causing disruptions.
- HP Officejet 4650 All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English / Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1200 pages
- Recommended Monthly Volume
- 100 - 400 pages
- Max Copying Speed
- Up to 7.5 ppm (mono) / up to 4 ppm (colour)
- Max Copying Resolution
- Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
- Max Printing Speed
- Up to 9.5 ppm (mono) / up to 6.8 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 1200 x 1200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.2"
- Original Size
- Letter A (216 x 279 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Media Type
- Plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- Output Trays Capacity
- 25 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, automatic paper sensor, Mobile Printing
- Power
- AC 120/230 V (50/60Hz)
- 44.5 cm x 36.9 cm x 19.1 cm
- 6.55 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 1200 pages
- 100 - 400 pages
- Display Diagonal Size
- 2.2"
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Localisation
- English / Ireland
- Standard Memory
- 64 MB
- Max Supported Memory
- 64 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 50
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 18 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 99 pages
- Fax Printing Speed
- Up to 20 ppm
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Delayed Transmission
- Remote Fax Retrieval (Polling)
- Fax forwarding
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 90 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C6 (114 x 162 mm), 101.6 x 152.4 mm, 76.2 x 127 mm, 127 x 177.8 mm, 215 x 355 mm, 203.2 x 254 mm, DL (210 x 99 mm), 215 x 309 mm, 76.2 x 140 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm)
- Borderless Photo Sizes
- 216 x 297 mm
- 100 sheets
- 25 sheets
- Input tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , ADF - 35 sheets , Output tray - 25 sheets
- Speed Details
- Printing: up to 9.5 ppm - B/W (ISO) , Printing: up to 6.8 ppm - colour (ISO) , Printing: up to 20 ppm - B/W draft , Printing: up to 16 ppm - colour draft , Copying: up to 7.5 ppm - B/W (ISO) , Copying: up to 4 ppm - colour (ISO) , Scanning: up to 8 ppm - B/W , Scanning: up to 4 ppm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x modem - RJ-11
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.8, Windows 8, Windows 8.1, Apple Mac OS X 10.9, Apple Mac OS X 10.10, Windows 10
- Software Included
- Drivers & Utilities, HP Photo Creations, HP Update
- Voltage Required
- 15 Watt
- Power Consumption Standby
- 3.45 Watt
- Power Consumption Sleep
- 0.65 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) - up to 190 pages - HP 63 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 63
- ENERGY STAR Certified
- Limited warranty - 1 year
- 44.5 cm
- 36.9 cm
- 19.1 cm
- 6.55 kg
- Shipping Weight
- 7.78 kg
- Sound Emission
- 50 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £15.28 |
