HP Officejet 4630 e-AiO Printer
Quicklinx: 9HG8WS00 Mfr#: B4L03B#BHC
Manage home office projects quickly and easily with this powerful wireless e-all-in-one. Print lab-quality photos and professional, two-sided documents at home or from a mobile device, and scan, copy or fax multipage documents hands-free.
  • Print, scan, copy and fax with this high productivity e-all-in-one with built-in ADF
    Leave stacks of papers to fax, scan or copy using the built-in 35-sheet automatic document feeder.Get professional-looking results – print borderless, lab-quality photos and crisp, laser-sharp documents.Save time and paper with automatic two-sided printing and copying.
HP Officejet 4630 e-All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
United Kingdom, Ireland, Nordics, Baltic Region
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
150 - 600 pages
Max Copying Speed
Up to 6 ppm (mono) / up to 4 ppm (colour)
Max Copying Resolution
Up to 300 x 300 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 8.8 ppm (mono) / up to 5.2 ppm (colour)
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
Scanning
1200 x 1200 dpi
Display
2"
Original Size
Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
Standard Media Capacity
100 sheets
Max Media Capacity
100 sheets
Output Trays Capacity
30 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, automatic paper sensor
AC 120/230 V (50/60Hz)
44.5 cm x 33.1 cm x 18.8 cm
6.22 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
1000 pages
150 - 600 pages
Display Diagonal Size
2"
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Standard Memory
64 MB
Max Supported Memory
64 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
20
Automatic Duplexing
Copying Features
Fit to page, ID Card Copy
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
19 sec
First Print Out Time Colour
24 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
Total Memory Capacity
Up to 99 pages
PC Faxing
Fax Machine Features
Speed Dialing
99 station(s)
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 101.6 x 152.4 mm, 76 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International B5 (176 x 250 mm), A4 (210 x 297 mm)
Borderless Photo Sizes
A4 (210 x 297 mm)
100 sheets
Max Media Capacity
100 sheets
30 sheets
Input tray - 100 sheets - Legal (216 x 356 mm) , Output tray - 30 sheets - Legal (216 x 356 mm) , ADF - 35 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 8.8 ppm - B/W (ISO) , Printing: up to 5.2 ppm - colour (ISO) , Printing: up to 21 ppm (Letter A) - B/W draft , Printing: up to 17 ppm (Letter A) - colour draft , Copying: up to 6 ppm - B/W , Copying: up to 4 ppm - colour , Printing: up to 21 ppm (A4) - B/W draft , Printing: up to 17 ppm (A4) - colour draft
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8
Software Included
Drivers & Utilities, HP Photo Creations
15 Watt
Power Consumption Standby
3.2 Watt
Power Consumption Sleep
0.7 Watt
USB cable, phone cable
Consumables Included
1 x ink cartridge (black) - up to 190 pages - HP 61 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 61
EN 61000-3-2, EN55022, EN 61000-3-3, CISPR 22, FCC CFR47 Part 15, EN 62311, EN55024:1998 + A1 + A2, IEC 62479, EN 62479:2010, IEC/EN60950-1:2006 +A11:2009 +A1:2010, IEC 62311, IEC 60950-1:2005 (ed.2)+A1:2009
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - phone consulting - 1 year
44.5 cm
33.1 cm
18.8 cm
6.22 kg
Shipping Width
49.1 cm
Shipping Depth
39.3 cm
Shipping Height
22.5 cm
Shipping Weight
7.56 kg
Sound Emission
49.1 dBA (operating)
5 °C
15 - 80%
9HG8 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.71
9HG8 HP 301XL High Yield Tri-colour Original Ink Cartridge In Stock £30.89
9HG8 HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.72
