HP OfficeJet 250 Mobile Printer
PORTABILITY MEETS PRODUCTIVITY!
Limited Time Offer
Cashback
Quicklinx: CBJ7WS00 Mfr#: CZ992A#BHC
Type: Printer / copier / scanner
Functionality: Printer, Scanner, Copier
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Thermal Ink-jet
More than 50 In Stock
£241.74 ex VAT
£290.08 inc VAT
Print, scan, and copy from nearly anywhere with this portable all-in-one. Easily connect to your printer with Bluetooth Smart technology and Wi-Fi Direct. This quiet workhorse has a long battery life and delivers the most pages.
Print, scan, and copy with this compact, portable all-in-one with a 10-sheet automatic document feeder. Easily connect and print from your mobile device using Wi-Fi Direct® – no network required.
Quickly print, copy, and scan multipage documents hands-free with the 10-page automatic document feeder. Simply connect and print from your laptop or mobile devices. Start printing right out of the box with quick and easy setup, using HP Auto Wireless Connect. This durable, compact all-in-one fits in your car, backpack, and more for convenient printing anywhere.
Count on inspired design and lasting quality from a printing leader. Flexible power options let you charge in the car, office, and home. Quiet performance reduces interruptions while Original HP inks deliver affordable, high-quality documents.
Power through the workday. Charge from home, in your car or office, and more. Plug in your AC power source to charge within 90 minutes while the printer is off, with HP Fast Charge. Minimize disruptions with premium design and quiet performance. Impress clients, without noisy interruptions. Get high-quality prints time after time with an all-in-one designed and built to be reliable.
Get exceptional performance with fast mobile print speeds and cartridges that let you print more pages than other in-class cartridges. Reduce interruptions with fewer supplies replacements and a long battery life.
Reduce charging interruptions with a long-lasting battery. Get the highest page yields of any in-class all-in-one, using Original HP cartridges. Set the pace for success wherever you go. Keep moving through the day with fast print speeds. The 6.73 cm (2.65-inch) colour touchscreen makes for easy printing, scanning, and copying.
  • Portability meets productivity
    Quickly print, copy, and scan multipage documents hands-free with the 10-page automatic document feeder.Simply connect and print from your laptop or mobile devices.Start printing right out of the box with quick and easy setup, using HP Auto Wireless Connect.This durable, compact all-in-one fits in your car, backpack, and more for convenient printing anywhere.
  • Lead the way with fast, easy mobile printing
    Reduce charging interruptions with a long-lasting battery.Get the highest page yields of any in-class all-in-one, using Original HP cartridges.Set the pace for success wherever you go. Keep moving through the day with fast print speeds.The 6.73 cm (2.65-inch) colour touchscreen makes for easy printing, scanning, and copying.
  • High-powered quality and reliability
    Power through the workday. Charge from home, in your car or office, and more.Plug in your AC power source to charge within 90 minutes while the printer is off, with HP Fast Charge.Minimise disruptions with premium design and quiet performance. Impress clients, without noisy interruptions.Get high-quality prints time after time with an all-in-one designed and built to be reliable.
HP Officejet 250 Mobile All-in-One - multifunction printer - colour
Multifunction printer
Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
500 pages
Recommended Monthly Volume
100 - 300 pages
Max Copying Speed
Up to 8 ppm (mono) / up to 4 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 10 ppm (mono) / up to 7 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Display
2.65"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, recycled paper, photo paper, light-weight paper, glossy paper, matte paper
Standard Media Capacity
50 sheets
Max Media Capacity
50 sheets
Connection Availability
USB 2.0, USB host, Wi-Fi
Office Machine Features
Save to USB flash drive, automatic paper sensor
AC 110/230 V (50/60Hz)
38 cm x 19.81 cm x 9.14 cm
2.95 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Ink-jet - colour
500 pages
100 - 300 pages
Display Diagonal Size
2.65"
Display Features
Touch screen
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
50
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
First Print Out Time B/W
11 sec
First Print Out Time Colour
13 sec
Scanning
Scan Element
CIS
Optical Resolution
600 x 600 dpi
Colour Depth
24-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 88.9 x 127 mm, 76.2 x 101.6 mm, 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 127 x 203.2 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Borderless Photo Sizes
127 x 177 mm
50 sheets
Max Media Capacity
50 sheets
Input tray - 50 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 10 ppm - B/W (ISO) , Printing: up to 7 ppm - colour (ISO) , Copying: up to 18 ppm (Letter A) - B/W draft , Copying: up to 15.5 ppm (Letter A) - colour draft , Printing: up to 20 ppm (Letter A) - B/W draft , Printing: up to 19 ppm (Letter A) - colour draft , Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 19 ppm (A4) - colour draft , Printing: up to 7 ppm - colour (ISO) , Copying: up to 18 ppm (A4) - B/W draft , Copying: up to 8 ppm - B/W (ISO) , Copying: up to 4 ppm - colour (ISO) , Copying: up to 2 ppm (Letter A) - B/W best , Copying: up to 1 ppm (Letter A) - colour best , Copying: up to 2 ppm (A4) - B/W best , Copying: up to 1 ppm (A4) - colour best
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Operating System Support
Linux, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
Power Consumption Standby
3.4 watt
Power Consumption Sleep
0.81 watt
Lithium-ion battery
Consumables Included
1 x ink cartridge (black) - up to 200 pages - HP 62 , 1 x ink cartridge (yellow/cyan/magenta) - up to 120 pages - HP 62
ENERGY STAR Certified
Limited warranty - 1 year
38 cm
19.81 cm
9.14 cm
2.95 kg
Shipping Width
51.7 cm
Shipping Depth
24.2 cm
Shipping Height
13.2 cm
Shipping Weight
4.8 kg
15 - 90%
Ink (7)
CBJ7 HP 62 Black Ink Cartridge In Stock £16.28
CBJ7 HP 62 Tri-color Ink Cartridge In Stock £19.38
CBJ7 HP 62XL Black Ink Cartridge In Stock £40.76
CBJ7 HP 62XL Tri-Color Ink Cartridge In Stock £42.16
CBJ7 HP 62 2-pack Black/Tri-color Original Ink Cartridges In Stock £35.32
CBJ7 HP 62XL High Yield - Black - Original - Ink Cartridge In Stock £41.09
Other bundles (2)
CBJ7 HP Care Pack Next Day Exchange HW Support Extended Service Agreement 3 Years Shipment for OfficeJet In Stock £55.94
CBJ7 HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment In Stock £44.76
Functionality: Scanner
Functionality: Copier
Output Type: Colour
Wireless Capability: Wireless
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
