HP NVIDIA NVS 310 - Graphics card - Quadro NVS 310 - 1 GB DDR3
Quicklinx: CKMDWS00 Mfr#: M6V51AT
Improve your graphics experience - Experience PCI Express x 16 graphics technology in a low profile card for your small form factor PC.
The NVIDIA NVS 310 graphics board offers 1GB of ultrafast DDR3 memory and is capable of supporting up to 2 displays.
Reduce the need to share your PC system memory with 1GB of DDR3, dedicated on-board graphics memory. (Graphics cards use part of the total system memory (RAM) for graphics performance. System memory dedicated to graphics performance is not available for other use by other programs.)
Run dual displays with the integrated DisplayPort 1.2 connector for more screen real-estate in graphic-intensive applications.
Enable DX11 applications and OpenGL applications for optimal performance with hardware-ready DirectX11 and OpenGL4.2 support.
NVIDIA NVS 310 - graphics card - Quadro NVS 310 - 1 GB - Smart Buy
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro NVS 310
1 GB DDR3
Effective Memory Clock
875 MHz
Max Resolution
2560 x 1600
Max Monitors Supported
2
Interfaces Details
2 x DisplayPort
API Supported
DirectX 11, OpenGL 4.1
15.6 cm x 6.89 cm
Manufacturer Selling Program
HP Smart Buy
1-year warranty
HP 4000 Pro, 6005 Pro, 6200 Pro, 6300 Pro, 8200 Elite, Elite 8300, Pro 4300; EliteDesk 705 G3, 705 G4, 800 G2 (SFF, tower); ProDesk 400 G3 (micro tower), 400 G4, 490 G3, 600 G2 (micro tower, SFF); Workstation Z440, Z640, Z840
Bus Type
PCI Express 2.0 x16
Graphics Engine
Max Resolution
2560 x 1600 at 60 Hz
2
Interfaces Details
2 x DisplayPort
API Supported
NVIDIA Mosaic, Shader Model 5.0
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
875 MHz
Bandwidth
14 GBps
Red Hat Enterprise Linux, Microsoft Windows 7 Professional (32/64 bits), SUSE Linux Enterprise Desktop 11 (32/64-bit), Windows 8 / 8.1
19.5 Watt
15.6 cm
6.89 cm
142 g
HP Smart Buy
Limited warranty - 1 year
HP EliteDesk 705 G3, 705 G4, 800 G2 (SFF, tower) , HP ProDesk 400 G3 (micro tower), 400 G4, 490 G3, 600 G2 (micro tower, SFF) , HP Workstation Z440, Z640, Z840 , HP Compaq 4000 Pro, 6005 Pro, 6200 Pro, 6300 Pro, 8200 Elite, Elite 8300, Pro 4300
