HP N246v 23.8" 1920x1080 5ms VGA DVI HDMI IPS LED Monitor
Quicklinx: FBRHWS00 Mfr#: 3NS59AA#ABU
Experience remarkable detail on the large-screened, Full HD N246v 23.8-inch Monitor with a sharp 1920 x 1080 resolution and wide viewing angles. The vibrant views, convenient connectivity, adaptability, and affordable price point are ideal for everyday business.
  • Stunning views
    See your work on a spacious 23.8-inch diagonal screen with wide 178-degree viewing angles, Full HD 1920 x 1080 resolution for a bright picture quality, and a 10M:1 Dynamic Contrast Ratio for sharp, crisp details.
  • Create workspace comfort
    Establish an efficient workspace with customizable tilt adjustment, an internal power supply, and direct mount capabilities by attaching select HP PCs to the back of the monitor or by mounting the display using the VESA pattern.
  • convenient Connectivity
    Easily connect devices with centralized HDMI, DVI, and VGA ports for digital access and legacy compatibility.
HP N246v - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A+
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
19 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (overdrive)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
54.66 cm x 20.99 cm x 40.51 cm
3.65 kg
English / United Kingdom
Plug and Play, TUV, CB, CCC, WEEE, CECP, CEL, SEPA
Display Type
Energy Class
Class A+
27 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms (overdrive)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Mercury free, arsenic free, 72% NTSC colour gamut
54.66 cm x 20.99 cm x 40.51 cm - with stand
3.65 kg
VGA , HDMI (HDCP) , DVI
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.5 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
19 W
Power Consumption (Typical)
22 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 54.66 cm - depth: 20.99 cm - height: 40.51 cm - weight: 3.65 kg , Without stand - width: 54.66 cm - depth: 4.47 cm - height: 32.1 cm - weight: 3.3 kg
Shipping Width
60.7 cm
Shipping Depth
12.5 cm
Shipping Height
40.5 cm
Shipping Weight
3.65 kg
5 °C
35 °C
20 - 80% (non-condensing)
FBRH HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £32.96
