A New Paradigm in Computing Efficiency. Stretch computing budgets by delivering a familiar, reliable computing experience to multiple users from a single, dedicated PC for maximum cost savings, management and power efficiency.
Expand existing budgets
Add 2x the computing seats without increasing your budget by leveraging the excess capacity of a single PC to deliver a dependable PC experience to multiple users. Save even more with lower IT management costs. -
Completely licensed and supported for worry-free computing
Deliver a fully supported Microsoft Windows experience for up to 10 simultaneous users with confidence that the latest OS security patches & updates work seamlessly when installed. -
Simple setup and deployment
Add seats to your computing environment with simple plug-and-play USB connectivity and all software preinstalled- no networking needed or software to load. -
Personal PC experiences
A familiar, customizable Microsoft Windows experience with simple collaboration and more reliability for higher uptime for greater productivity. -
Reduce environmental impact
At only up to 2.5 watts per access device, multi-seat computing can greatly reduce power consumption over traditional PCs. Plus, the HP MultiSeat t100 Thin Client and its cables contain no hazardous PVCs or BFRs.
- HP MultiSeat t100 - tower no CPU - no HDD
- Zero client - tower
- Processor
- No CPU
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- No graphics
- OS Provided
- Microsoft Windows MultiPoint Server 2010
- 11.2 cm x 6.5 cm x 2.8 cm
- 136 g
- Zero client
- Product Form Factor
- Tower
Processor / Chipset
- CPU
- No CPU
- CPU Upgradability
- Upgradable
Hard Drive
- No HDD
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
- Video Interfaces
- VGA
Input Device
- Mouse, keyboard
- 1 x USB 2.0 , 1 x VGA , 2 x PS/2 keyboard / mouse , 1 x audio line-out , 1 x microphone
- Theft/Intrusion Protection
- FCC Class B certified, CISPR 22 Class B, CISPR 24, EN 60950, EN55022, EN55024
Operating System / Software
- OS Provided
- 11.2 cm
- 6.5 cm
- 2.8 cm
- 136 g
- 10 °C
- 40 °C
- 10 - 90%
