HP mt45 Ryzen 3 PRO 3300U 8GB 128GB 14" ThinPro OS
Quicklinx: F8PZWS00 Mfr#: 3JH21EA#ABU
  • IEEE 802.11n
Achieve the perfect balance of form and function with the beautifully designed HP mt45 Mobile Thin Client. It's offers built-in collaboration features such as a world-facing third mic, collaboration keys and loud speakers.
  • Optimized for your cloud and VDI environments
    Enjoy premium virtualization with industry ISV partners, including Citrix , VMware , and Microsoft , plus features like a cloud-connectable integrated browser, single sign-on support, and multimedia redirection.
  • Fast charging, fewer cables
    Power-up in a flash with optional HP Fast Charge adapter, which charges your battery up to 50% in 30 minutes. Access everything - network, data, video, and power charging with one simple USB-C cable connected from your dock to your thin client.
  • Next-level security
    Help ensure data security by keeping it off the local device. Get added protection from the TPM 2.0 chipset, Windows Enterprise security features and HP Write Manager, which defends against unauthorized updates and viruses.
  • Management simplified
    Make it easy to deploy, manage, and maintain your install base onsite or remotely with HP Device Manager, a software tool available exclusively for HP Thin Clients.
  • Quick. Clean. Streamlined
    Customize an intuitive interface and level of protection to fit your needs, and maximize your cloud infrastructure, VDI, and kiosk environments with HP Easy Shell software, designed to optimize your Windows Embedded user experience.
  • Stay Connected
    Your "office" can be where you need it, letting you stay connected almost everywhere with a reliable wireless LAN connection with enhanced signal strength and supports optional 4G LTE category 9 wireless broadband technology.
HP Mobile Thin Client mt45 - 14" - AMD Ryzen 3 Pro - 3300U - 8 GB RAM - 128 GB SSD - UK
Mobile thin client
Operating System
HP ThinPro - English
AMD Ryzen 3 Pro 3300U / 2.1 GHz, up to 3.5 GHz / 4 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
128 GB SSD - TLC
Display
14" WLED 1920 x 1080 / Full HD
Graphics
AMD Radeon Vega 6
Input Device
Keyboard, pointing stick, ClickPad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, NFC, Bluetooth 5.0, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
32.6 cm x 23.43 cm x 1.79 cm
1.53 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Mobile thin client
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
L3 - 4 MB
64-bit Computing
RAM
8 GB (2 x 4 GB)
Max RAM Supported
8 GB
DDR4 SDRAM
Speed
2400 MHz / PC4-21300
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
128 GB SSD M.2 2280 SATA 6Gb/s - triple-level cell (TLC)
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
AMD Radeon Vega 6
Camera
Yes - HD
Video Resolutions
720p
Camera Features
IR camera, HP Privacy HD
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Output: noise-cancellation technology, Bang & Olufsen Audio
Input
Keyboard Layout
Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 9260 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Miracast, dual stream (2x2)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, Bluetooth 5.0
3-cell Lithium Ion
50 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
Interfaces Details
USB-C , USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , HDMI , Headphone/microphone combo jack , Dock , LAN
Software
Software Included
Citrix ICA, Microsoft RDP, HP Device Manager, HP Hotkey Support, Windows Defender, VMware Horizon View, HP Secure Erase, Microsoft Internet Explorer 11, HP BIOS Config Utility, HP ThinUpdate, HP Easy Shell, HP Noise Cancellation, Native Miracast, HP USB Port Manager, HP Connection Optimizer, Power On Authentication, HP Write Manager, HP BIOSphere Gen5, HP SureStart Gen5
Case Material
Aluminum
Dockable
Security
Power-on password, Setup Password, BIOS Absolute Persistence, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MU-MIMO technology, Master Boot Record Security, BIOS Update via Network
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, CCC, FCC, MIL-STD 810G, Common Criteria EAL4+, KC, low halogen, ICCP, AUS/NZ
Localization
1.53 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
F8PZ HP 65W Smart AC Adapter In Stock £17.30
F8PZ HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £184.27
F8PZ HP SS03050XL-PL - Laptop Battery - Li-Ion - 4.33 Ah - 50 Wh In Stock £57.76
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
F8PZ HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £105.71
Other bundles (3)
F8PZ HP USB-C To VGA Adapter In Stock £23.07
F8PZ HP USB Travel Mouse In Stock £9.23
F8PZ HP USB-C to HDMI 2.0 Adapter In Stock £47.25
