Achieve the perfect balance of form and function with the beautifully designed HP mt45 Mobile Thin Client. It's offers built-in collaboration features such as a world-facing third mic, collaboration keys and loud speakers.
Optimized for your cloud and VDI environments
Enjoy premium virtualization with industry ISV partners, including Citrix , VMware , and Microsoft , plus features like a cloud-connectable integrated browser, single sign-on support, and multimedia redirection. -
Fast charging, fewer cables
Power-up in a flash with optional HP Fast Charge adapter, which charges your battery up to 50% in 30 minutes. Access everything - network, data, video, and power charging with one simple USB-C cable connected from your dock to your thin client. -
Next-level security
Help ensure data security by keeping it off the local device. Get added protection from the TPM 2.0 chipset, Windows Enterprise security features and HP Write Manager, which defends against unauthorized updates and viruses. -
Management simplified
Make it easy to deploy, manage, and maintain your install base onsite or remotely with HP Device Manager, a software tool available exclusively for HP Thin Clients. -
Quick. Clean. Streamlined
Customize an intuitive interface and level of protection to fit your needs, and maximize your cloud infrastructure, VDI, and kiosk environments with HP Easy Shell software, designed to optimize your Windows Embedded user experience. -
Stay Connected
Your "office" can be where you need it, letting you stay connected almost everywhere with a reliable wireless LAN connection with enhanced signal strength and supports optional 4G LTE category 9 wireless broadband technology.
- HP Mobile Thin Client mt45 - 14" - AMD Ryzen 3 Pro - 3300U - 8 GB RAM - 128 GB SSD - UK
- Product Type
- Mobile thin client
- Operating System
- HP ThinPro - English
- Processor
- AMD Ryzen 3 Pro 3300U / 2.1 GHz, up to 3.5 GHz / 4 MB Cache
- Memory
- 8 GB DDR4 (2 x 4 GB)
- Storage
- 128 GB SSD - TLC
- Display
- 14" WLED 1920 x 1080 / Full HD
- Graphics
- AMD Radeon Vega 6
- Input Device
- Keyboard, pointing stick, ClickPad
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, NFC, Bluetooth 5.0, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 32.6 cm x 23.43 cm x 1.79 cm
- 1.53 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- RAM
- 8 GB (2 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz / PC4-21300
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 128 GB SSD M.2 2280 SATA 6Gb/s - triple-level cell (TLC)
Display
- 14" - IPS
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
- Keyboard Name
- HP Premium Collaboration Keyboard
Audio & Video
- Graphics Processor
- AMD Radeon Vega 6
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- IR camera, HP Privacy HD
- Sound
- Stereo speakers, 3 multi-array microphone
- Audio Features
- Output: noise-cancellation technology, Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 9260 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Miracast, dual stream (2x2)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, Bluetooth 5.0
- Technology
- 3-cell Lithium Ion
- Capacity
- 50 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB-C , USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , HDMI , Headphone/microphone combo jack , Dock , LAN
Software
- Software Included
- Citrix ICA, Microsoft RDP, HP Device Manager, HP Hotkey Support, Windows Defender, VMware Horizon View, HP Secure Erase, Microsoft Internet Explorer 11, HP BIOS Config Utility, HP ThinUpdate, HP Easy Shell, HP Noise Cancellation, Native Miracast, HP USB Port Manager, HP Connection Optimizer, Power On Authentication, HP Write Manager, HP BIOSphere Gen5, HP SureStart Gen5
- Case Material
- Aluminum
- Dockable
- Security
- Power-on password, Setup Password, BIOS Absolute Persistence, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MU-MIMO technology, Master Boot Record Security, BIOS Update via Network
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, CCC, FCC, MIL-STD 810G, Common Criteria EAL4+, KC, low halogen, ICCP, AUS/NZ
- Localization
- 1.53 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HP 65W Smart AC Adapter | In Stock | £17.30 |
HP SS03050XL-PL - Laptop Battery - Li-Ion - 4.33 Ah - 50 Wh | In Stock | £57.45 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £105.71 |
Other bundles (3)
HP USB-C To VGA Adapter | In Stock | £23.07 |
HP USB Travel Mouse | In Stock | £9.23 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.25 |
