HP MSA2324I DC MODULAR SMART ARRAY (SFF)
Quicklinx: 6922WS00 Mfr#: AJ802A
The HP 2000i G2 Modular Smart Array selection of SAN devices features the very latest in efficient consolidation, functionality and technology at very affordable prices. The ideal customers needing to consolidate their storage include smaller companies with tight budgets and limited IT expertise, or larger companies that have perhaps hundreds of smaller departments and remote locations. The MSA2000i G2 features a 1 Gb Ethernet (1 GbE) iSCSI connected array. It allows customers to grow their storage as demands increase up to 36 TB SAS or 120 TB SAS MDL or SATA MDL, supporting up to 32 hosts for iSCSI attach. All models support the optional HP 2000 Modular Smart Array Snapshot Software which offers controller-based snapshot and cloning functionality. Planning for future growth is easy by starting with the basic modular pieces and adding capacity as needs arise.
  • Easily managed highly affordable storage consolidation
    The HP 2000i G2 Modular Smart Array delivers low cost, consolidated storage array technology to meet departmental and small to medium businesses requirements with solutions matched with the latest SAS, SAS MDL and SATA MDL drives.The MSA2000i G2 arrays offer a choice of drives: high performance enterprise class SAS drives and low cost, high capacity archival class SATA. Various models comes standard with 12 or 24 drive bays able to simultaneously accommodate 2.5-inch or 3.5-inch dual-ported SAS, SAS MDL and SATA MDL drives.The MSA2000i G2 offers single and dual controller configurations. Build a single controller model for lowest initial investment, or choose a dual controller model for greater data protection. Balance performance with cost by choosing lower cost SAS MDL or SATA MDL drives for archival areas.The MSA2000i G2 array allows customers to grow their storage as demands increase up to 36 TB SAS or 120 TB SAS MDL or SATA MDL, and support up to 32 hosts for iSCSI. The MSA2000i G2 array can support up to 4 LFF drive enclosures and 60 drives or 3 SFF drive enclosures and a maximum of 99 drives.
  • Start small and grow in number of supported servers and total capacity
    The MSA2000i G2 with 512 LUNs has more than sufficient LUNs for storage configuration flexibility.All models support the optional HP MSA2000 Snapshot Software which offers controller-based Snapshot and cloning functionality for increased data protection. Controller-based snaps produce space-efficient, copy-on-write Snapshots and clones.Reduce risk of IT failure with active/active controllers, dual-ported drives, and redundant hardware components.RAID 0, 1, 3, 5, 6, 10, 50. Redundant hardware with automatic failover resulting in less downtime.
  • Comprehensive data protection in an easily administered SAN environment
    Reduced time to operation with easy and secure deployment. Reduced risk from operator errors, resulting in less downtime and data loss, while increasing customer satisfaction. Supports customer replaceable hot plug components such as drives, controllers, fans and power supplies.The array units occupy 2U of rack space and include 12 or 24 drive bays. They come standard with built-in persistent cache protection so there is no need to buy a special UPS for this purpose, giving a cost saving as well as saving rack space. Added drive enclosures also only take 2U of rack space.
HPE StorageWorks Modular Smart Array 2324i G2 Dual Controller - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
iSCSI
0 (installed) / 24 (max)
Supported Drives
SATA-300 / SAS
Storage Controller
RAID (SATA 3Gb/s / SAS) - RAID RAID 0, 1, 3, 5, 6, 10, 50
Storage Controller Quantity
2
Hard Drive
0 HDD SATA 3Gb/s / SAS - hot-swap
Red Hat Linux 5.0, SuSE Linux 10.0, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows 2003, Microsoft Windows 2003 R2, VMware ESX Server
Power Redundancy
44.6 cm x 51.5 cm x 8.7 cm
19.5 kg
3-year warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
24
Supported Drives
SATA-300 / SAS
Storage
HDD Array External Interface
iSCSI
Storage Controller
RAID (iSCSI)
Installed Qty
2
Interface Type
SATA 3Gb/s / SAS
Data Transfer Rate
300 MBps
Cache / Buffer Size (Max)
1 GB
Supported Devices
Disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 50
Storage Controller (2nd)
Installed Qty
2
Hard Drive
HDD - hot-swap
0
Interface Type
SATA 3Gb/s / SAS
Expansion Bays
24 (total) / 24 (free) - 2.5" SFF
2 x serial RS-232 - 9 pin D-Sub (DB-9) , 2 x management - RJ-45 , 4 x Ethernet 1000Base-T - RJ-45 , 2 x SAS - 4 x InfiniBand (SFF-8470)
CISPR 22 Class A, CISPR 24, EN55022, EN55024, ICES-003 Class A, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, FCC CFR47
Power Redundancy
Power Redundancy Scheme
1+1
44.6 cm
51.5 cm
8.7 cm
19.5 kg
Limited warranty - 3 years
5 °C
10 - 90%
