The HP mt43 Mobile Thin Client delivers exceptional design and remarkable performance in an elegant, yet durable device. So your most important work gets done in style.
Designed to turn heads
The HP mt43 Mobile Thin Client is crafted with premium materials for a thin, light, elite look and feel. Get an exceptional user experience with a backlit keyboard, large-format glass touchpad and expert audio tuning by Bang & Olufsen. -
Engineered for powerful, reliable performance
Whether at your desk or on the go, the HP mt43 Mobile Thin Client offers great reliability, elite processing power, and flexible connectivity for maximum productivity. -
Built to withstand the rigors of professional life
The HP mt43 Mobile Thin Client is built to protect your most important work with rugged durability for the mobile professional.
- HP Mobile Thin Client mt43 - 14" - AMD A8 - PRO-9600B - 8 GB RAM - 128 GB SSD - UK
- Product Type
- Mobile thin client
- Operating System
- Win 10 IoT Enterprise 64-bit - English
- Processor
- AMD A8 PRO-9600B / 2.4 GHz, up to 3.3 GHz / 2 MB Cache
- Memory
- 8 GB DDR4 (2 x 4 GB)
- Storage
- 128 GB SSD - TLC, HP Value
- Display
- 14" LED backlight 1920 x 1080 / Full HD - 157 ppi
- Graphics
- AMD Radeon R5
- Input Device
- Keyboard, touchpad, pointing stick
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell - up to 15.5 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- 33.8 cm x 22.7 cm x 1.89 cm
- 1.48 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - parts and labour - 1 year
- Product Type
- Operating System
- Windows 10 IoT Enterprise 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 8 GB (2 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 1866 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 128 GB SSD M.2 SATA 6Gb/s - triple-level cell (TLC), HP Value
Display
- 14" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Pixel Density (ppi)
- 157
- Image Brightness
- 300 cd/m²
- Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare
- Keyboard Name
- HP Advanced
Audio & Video
- Graphics Processor
- AMD Radeon R5
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- DTS Studio Sound
- Audio Features
- Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
- Keyboard Layout
- UK
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5762
- Dual stream (2x2)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- Technology
- 3-cell lithium polymer
- Capacity
- 51 Wh
- Run Time
- Up to 15.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V
Connections & Expansion
- Slots
- 1 x Micro-SIM card (1 free)
- Interfaces Details
- USB-C , 2 x USB 3.1 (charging) , VGA , LAN , DisplayPort , Headphone/microphone combo jack , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- HP Device Manager, HP Velocity, HP Secure Erase, HP BIOSphere, LANDesk Management Suite (free download), HP Easy Shell, HP Noise Cancellation, HP LAN-WLAN Protection, HP MAC Address Manager
- Dockable
- Security
- TPM Enhanced DriveLock, HP DriveLock, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
- Localization
- 1.48 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
Get more from your purchase from one of our essential accessories
HP 90W Smart AC Adapter | In Stock | £22.02 |
