Hit the road with reliable security and efficient manageability with the HP mt41 Mobile Thin Client. Connect wherever you have access to the cloud with this thin, light and conveniently accessible mobile device. Rest easy with multiple security features and quick access to shared data, all within an enterprise-grade durable design.
Designed to turn heads
The HP mt43 Mobile Thin Client is crafted with premium materials for a thin, light, elite look and feel. Get an exceptional user experience with a backlit keyboard, large-format glass touchpad and expert audio tuning by Bang & Olufsen. -
Engineered for powerful, reliable performance
Whether at your desk or on the go, the HP mt43 Mobile Thin Client offers great reliability, elite processing power, and flexible connectivity for maximum productivity. -
Built to withstand the rigors of professional life
The HP mt43 Mobile Thin Client is built to protect your most important work with rugged durability for the mobile professional.
- HP Mobile Thin Client mt41 - 14" - AMD A4 - 5150M - 4 GB RAM - 16 GB SSD - 4G LTE
- Product Type
- Mobile thin client
- Operating System
- Win Embedded Standard 7E 32-bit
- Processor
- AMD A4 5150M / 2.7 GHz, up to 3.3 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 16 GB SSD
- Display
- 14" LED backlight HD anti-glare 1366 x 768 / HD
- Graphics
- AMD Radeon HD 8350G
- Input Device
- Keyboard, touchpad
- Networking
- 802.11a/b/g/n, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Battery
- 6-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
- 34 cm x 23.7 cm x 2.9 cm
- 2.08 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - 3 years
- Product Type
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows Embedded Standard 7E 32-bit
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- Chipset
- AMD A76M FCH
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 16 GB SSD SATA 6Gb/s
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HD anti-glare, privacy filter
Audio & Video
- Graphics Processor
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD87
- High Definition Audio
Input
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- 802.11a/b/g/n
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8151GH-CG
- Remote Management Protocol
- SNMP
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, Wi-Fi CERTIFIED, IEEE 802.3az
- Generation
- 4G
- Technology
- GSM, GPRS, EDGE, HSDPA, WCDMA, HSUPA, HSPA+, LTE
- Controller
- HP lt4112
Navigation
- Receiver
- GPS
- Technology
- 6-cell Lithium Ion
- Installed Qty
- 1
- Capacity
- 55 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 18.5 V
Connections & Expansion
- VGA , DisplayPort , Headphone/microphone combo jack , LAN , 4 x USB 2.0 , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- HP Device Manager, HP Velocity
- Dockable
- Security
- Charging via USB, Preboot Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, FCC Class B certified, CSA, UL, ISO 9241, ISO 14001, CCC, Green Mark, ISO 9995, E-Standby, ISO 7779, CECP
- Localization
- 2.08 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
