Take your workload by the horns with the HP mt42 Mobile Thin Client, HP's thinnest, lightest, and most powerful mobile thin client. Access the cloud and your virtual desktop with Windows 10 IoT Enterprise for Thin Clients on a stylish and fully-loaded design without the bulk.
Super-charged data delivery
Improve wired and Wi-Fi network performance and the end user experience with HP Velocity software. -
Next-level security
Help ensure data security by keeping it off the local device, and get added protection from the TPM chipset and Windows with Write Filter. -
Management simplified
Make it easy to deploy, manage, and maintain your install base with HP Device Manager. -
Quick. Clean. Streamlined
Simplify the HP Thin Client Windows Embedded user experience with HP Easy Shell's customized interface and protection for targeted cloud control. -
Work with what you know on the go
Feel right at home and make life easier for IT administrators with Windows 10 IoT Enterprise for Thin Clients, which supports Microsoft Office 365 and your peripheral drivers. -
Designed-in communication tools
Easily collaborate with Ethernet and wireless networking, broadened unified communications support, and integrated audiovisual features.
- HP Mobile Thin Client mt42 - 14" - AMD A8 - PRO-8600B - 4 GB RAM - 32 GB SSD - UK
- Product Type
- Mobile thin client
- Operating System
- Win Embedded Standard 7E 32-bit - English
- Processor
- AMD A8 PRO-8600B / 1.6 GHz, up to 3 GHz
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 32 GB SSD
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- AMD Radeon R6
- Input Device
- Keyboard, touchpad
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
- 33.8 cm x 23.7 cm x 1.89 cm
- 1.54 kg
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Operating System
- Microsoft Windows Embedded Standard 7E 32-bit - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Quad-Core
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 32 GB SSD M.2 SATA 6Gb/s
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 300 cd/m²
- Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare +PSR
Audio & Video
- Graphics Processor
- AMD Radeon R6
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC3228
- DTS Studio Sound
- Audio Features
- Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
- Keyboard Layout
- UK
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5762
- IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, Bluetooth 4.0
- Technology
- 3-cell Lithium Ion
- Capacity
- 46 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 9.5 V
Connections & Expansion
- Slots
- 1 x Micro-SIM card (1 free)
- Interfaces Details
- USB-C , USB 3.0 , VGA , LAN , DisplayPort , Headphone/microphone combo jack , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- HP Device Manager, HP Velocity, HP Easy Shell
- Dockable
- Security
- TPM Enhanced DriveLock, 1 USB 3.0 charging port, Pre-boot Authentication
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 1.54 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
