HP ML330 G6 Dual Processor Capable, 1 x Xeon E5606 (2.13Ghz)
Quicklinx: 7D0SWS00 Mfr#: 637081-035
  • Xeon
  • DVD-RW
The HP ProLiant ML330 G6 is a dual processor tower platform which is built on the latest Intel Xeon processors with QPI technology to create a unique system architecture. This unique architecture allows the businesses to scale their businesses as needed so they can optimize their IT spending dollars. The HP ProLiant ML330 G6 delivers to businesses the industry's most powerful embedded management technology with the HP Integrated Lights-Out 2 (iLO 2), which allows them to manage the servers anytime and from anywhere.
  • Unique system architecture for performance and affordability
    Maximize Intel's ultimate 6 core processor with latest QPI technology and multi-threaded applications for faster execution.Provides the latest Intel system architecture to support 2 Xeon processors with HP's unique scalable architecture.Advanced Smart Array RAID controllers provide up to RAID 6/60 data protection and add high availability to HDD performance and efficiency.DDR3 delivers high-performance with maximum system memory capacity with less power consumption.
  • Highly flexible and expandable to meet future growth
    Upgradeable 2nd processor adds up to Xeon 2.66GHz with 12M cache with Turbo mode and 9 DDR3 DIMM sockets (total up to 18 system DIMM sockets) to ensure flexibility and performance evaluation.Up to 192GB DDR3 Registered or 48GB DDR3 Unbuffered system memory as well as 8 LFF HDD for either hot plug or non-hot plug SATA or SAS.Redundant power supplies, fans, memory and disks continuous support your business to maintain system efficiency and reliability.
  • Best tools for remote management, deployment as well as security
    HPE Integrated Lights-Out 2 is management functionality that simplifies server setup, health monitoring, power and thermal control, and remote administration. It functions without additional software and can be accessed locally or remotely.SmartStart deployment tool gets your server up and running in three easy steps.HPE Systems Insight Manager (SIM) keeps an eye on your server so that staff members can focus on priority projects. Alerts on system status can be delivered to you on your own terms.HPE Insight Control Environment suite (ICE) helps increase uptime, decreases down time, reduce costs and improve productivity by enabling systems management functions remotely-anywhere, anytime.Trusted Platform Module (TPM) protects secrets (Data), performs cryptographic functions, can create, store and manage keys, performs digital signature operations and holds platform measurements (hashes).
HPE ProLiant ML330 G6 - tower Xeon E5606 2.13 GHz - 2 GB - HDD 2 x 250 GB
Server - tower - system password, power-on password, diskette I/O control, serial port I/O control, USB port control, keyboard lock
Height (Rack Units)
5U
Server Scalability
2-way
1 x Intel Xeon E5606 / 2.13 GHz (Quad-Core)
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
2 GB (installed) / 48 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-10600
Storage Controller
RAID (SATA 3Gb/s) (Smart Array B110i); SAS (SATA 3Gb/s / SAS 6Gb/s) (Smart Array P410)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
2 x HDD 250 GB (hot-swap) - SATA 3Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
ATI ES1000
1GbE
Software Included
HP Insight Control
Windows Server Certified
This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
20 cm x 61.3 cm x 42.7 cm
16 kg
Limited warranty - parts - 3 years , Limited warranty - labour - 1 year , Limited warranty - 1 year - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Tower - 5U
Server Scalability
2-way
Front Accessible Bays Qty
3
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Intel Xeon E5606
Clock Speed
2.13 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel 5500
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
12 (Total) / 11 (empty)
Unbuffered, Memory Mirroring
Configuration Features
1 x 2 GB
RAM Supported
PC3-10600 - 144 GB registered , PC3-8500 - 192 GB registered , PC3-10600 - 48 GB unbuffered
Hard Drive
HDD - hot-swap
2 x 250 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
RAID - integrated
Controller Interface Type
SATA 3Gb/s
Storage Controller Name
Smart Array B110i
RAID Level
RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
SAS - integrated
Smart Array P410
RAID Level
Optical Storage
DVD-RW DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
ATI ES1000
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express x4
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC326i
Wake on LAN (WoL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
3 (total) / 2 (free) x external 5.25" x 1/2H , 4 (total) / 2 (free) x hot-swap 3.5" x 1/3H
Slots
2 (total) / 1 (free) x CPU , 12 (total) / 11 (free) x DIMM 240-pin , 2 (total) / 2 (free) x PCIe 2.0 x8 - half-length (x4 mode) , 1 (total) / 1 (free) x PCIe x8 - half-length (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x16 - half-length
1 x serial , 6 x USB 2.0 (2 front, 4 rear) , 1 x VGA , 3 x LAN (Gigabit Ethernet) , 1 x PS/2 keyboard , 1 x PS/2 mouse
System password, power-on password, diskette I/O control, serial port I/O control, USB port control, keyboard lock
ACPI 2.0
Power supply
Power Provided
460 Watt
Power Factor Correction
Operating System / Software
Software
HP Insight Control
20 cm
61.3 cm
42.7 cm
16 kg
10 °C
35 °C
10 - 95%
Resources
The following resources are available for the HP ML330 G6 Dual Processor Capable, 1 x Xeon E5606 (2.13Ghz)
