Brand
HP Main Battery Pack 11.1v 4600mAh
Quicklinx: 7ZFRWS00 Mfr#: CBI3233A
High quality internal battery, extended 9-cell main battery pack Guaranteed to meet or exceed the original manufacturer's specifications
Get extra performance
Product Description 2-Power Internal Battery - laptop battery - Li-Ion - 4600 mAh
Device Type Laptop battery
Dimensions (WxDxH) 21 cm x 6.9 cm x 2.3 cm
Weight 315 g
Battery Lithium Ion 6-cell - 4600 mAh
Battery Form Factor Internal
Batteries Qty 1
Manufacturer Warranty 1 year warranty
Designed For Dell Latitude E4200
Laptop battery
315 g
Battery Form Factor
Internal
Metallic grey
1-year warranty
Dell Latitude E4200
Laptop battery
Battery Enclosure Type
Internal
Metallic grey
6-cell Lithium Ion
Voltage Provided
11.1 V
4600 mAh
Limited warranty - 1 year
21 cm
6.9 cm
2.3 cm
315 g
Dell Latitude E4200
