High quality internal battery, extended 9-cell main battery pack Guaranteed to meet or exceed the original manufacturer's specifications
Get extra performance
Product Description 2-Power Internal Battery - laptop battery - Li-Ion - 4600 mAh
Device Type Laptop battery
Dimensions (WxDxH) 21 cm x 6.9 cm x 2.3 cm
Weight 315 g
Battery Lithium Ion 6-cell - 4600 mAh
Battery Form Factor Internal
Batteries Qty 1
Manufacturer Warranty 1 year warranty
Designed For Dell Latitude E4200
- 2-Power Internal Battery - laptop battery - Li-Ion - 4600 mAh
- Laptop battery
- 315 g
- Battery
- Lithium Ion 6-cell - 4600 mAh
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Metallic grey
- 21 cm x 6.9 cm x 2.3 cm
- 1-year warranty
- Designed For
- Dell Latitude E4200
- Laptop battery
- Battery Enclosure Type
- Internal
- Metallic grey
- Quantity
- 1
- Technology
- 6-cell Lithium Ion
- Voltage Provided
- 11.1 V
- Capacity
- 4600 mAh
- Limited warranty - 1 year
- 21 cm
- 6.9 cm
- 2.3 cm
- 315 g
- Designed For
