The HP SN03044XL-PL notebook battery is a reliable power solution for your PC, designed to keep you working or playing longer without the need for constant recharging. This battery features a 44 Wh capacity and utilizes 3-cell lithium-ion technology, offering a balance of longevity and performance. Its seamless compatibility with PC devices ensures that your device is powered efficiently, enhancing your experience whether you're at work or on-the-go. Manufactured by HP Inc., you can trust in the reliability and durability of this battery to meet your daily power needs.
Extended battery life
With a capacity of 44 Wh and 3-cell technology, this lithium-ion notebook battery ensures your PC stays powered longer, enabling extended usage and productivity without constantly searching for a power outlet. -
Seamless compatibility
Designed specifically for PC compatibility, this HP notebook battery integrates flawlessly with your device, ensuring a reliable and efficient power source that maximizes your device's performance.
 - HP SN03044XL-PL - laptop battery - Li-Ion - 44 Wh
 - Laptop battery
- Battery
 - Primary - Lithium Ion 3-cell - 44 Wh
- Designed For
 - EliteBook 725 G3 Notebook, 820 G3 Notebook
 - Laptop battery
 - Primary
- Technology
 - 3-cell Lithium Ion
- Capacity
 - 44 Wh
- Designed For
 - HP EliteBook 725 G3 Notebook, 820 G3 Notebook
