HP M476dn Colour LaserJet Pro Multifunction Printer
Quicklinx: 9DD6WS00 Mfr#: CF386A#B19
This HP Color LaserJet Pro MFP connects the whole office to vibrant colour printing, even on the go. See productivity improve with fast, versatile scanning that can send documents directly to email, network folders, and the cloud.
  • Print on your terms
    Print how and where you want: easily send print jobs wirelessly without a network.Enable touch-to-print convenience from mobile devices.Easily print from smartphone, tablets and notebooks at work, home, or on-the-go; with HP's first Mopria-certified MFP.Share all your printer has to offer – set up, print, and share with Ethernet and wireless connectivity.
  • Scan fast, and send securely
    Save time and get more done much faster: scan two-sided documents in a single pass, with no missed pages or flipping pages.Control access to walk-up features and easily look up network email addresses, using LDAP connectivity.Scan and send; it's simple. Capture and route digital files directly to the Cloud, email, or network folders.
  • Speed up your workflow
    Save time and help reduce paper costs, using automatic two-sided printing.Work smarter – access content and print from the Cloud using business apps on the control panel. Quickly launch tasks from the 8.9 cm colour touchscreen.Finish projects fast: use the 50-page automatic document feeder to save time.Just walk up to this MFP and print from or scan to your USB drive, using the easy-access USB port.
HP Color LaserJet Pro MFP M476dn - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
40000 pages
Recommended Monthly Volume
1000 - 2500 pages
Max Copying Speed
Up to 20 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 300 x 420 dpi (mono) / up to 300 x 420 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Display
3.5"
Original Size
Legal (216 x 356 mm) (max)
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
Standard Media Capacity
300 sheets
Max Media Capacity
550 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder, scan to network, scan to Cloud
AC 230 V
41.9 cm x 48.5 cm x 50 cm
28.9 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
40000 pages
1000 - 2500 pages
Display Diagonal Size
3.5"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, PCLm
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
First Print Out Time B/W
16.5 sec
First Print Out Time Colour
16.5 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
Fax Printing Speed
Up to 20 ppm
Fax Printing Resolution
300 x 300 dpi
PC Faxing
Yes (send only)
Fax Machine Features
Speed Dialing
120 station(s)
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax memory backup, delayed sending, fax polling, block fax, save and load speed dials, poll receive, fax activity reports, print fax log
Document & Media Handling
Max Original Size
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm
300 sheets
Max Media Capacity
550 sheets
50 sheets
150 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) , Bypass tray - 50 sheets , Output tray - 150 sheets
Speed Details
Printing: up to 21 ppm (Letter A) - B/W normal , Printing: up to 21 ppm (Letter A) - colour normal , Copying: up to 21 ppm (Letter A) - B/W normal , Copying: up to 21 ppm (Letter A) - colour normal , Scanning: up to 17 ppm (A4) - B/W normal , Scanning: up to 13 ppm (A4) - colour normal , Scanning: up to 31 ipm (A4) - B/W duplex , Scanning: up to 11 ipm (A4) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
LDAP
Operating System Support
HP-UX 11.x, SunSoft Solaris 2.5 or later, MS Windows XP SP2 or later, Sun Solaris 8, Sun Solaris 9, MS Windows 7, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows Vista, MS Windows 2000 Server, SuSe Linux 10.3, HP-UX 11i, MS Windows Server 2008, Novell NetWare 5.1, Apple Mac OS X 10.6, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Linux Linpus Desktop 9.4, Linux Linpus Desktop 9.5, Red Hat Linux 7.x or later, SUSE Linux 8.x or later, IBM AIX 3.2.5 or later, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, MS Windows Server 2008 R2 x64 Edition, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, HP-UX 10.20, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, MS Windows Server 2003 SP2 or later, Windows 8.1, Apple Mac OS X 10.9
Software Included
Drivers & Utilities, HP Web Jetadmin
AC 230 V
397 Watt
Power Consumption Standby
17.6 Watt
Power Consumption Sleep
1.5 Watt
Consumables Included
1 x toner cartridge (black) - up to 1200 pages , 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
41.9 cm
48.5 cm
50 cm
28.9 kg
Shipping Width
61.1 cm
Shipping Depth
60 cm
Shipping Height
50 cm
Shipping Weight
33.3 kg
Sound Emission
28 dB (operating)
15 °C
30 °C
20 - 70% (non-condensing)
9DD6 HP 312A Black Toner Cartridge In Stock £87.10
9DD6 HP 312A Cyan Toner Cartridge In Stock £116.61
9DD6 HP 312A Magenta Toner Cartridge In Stock £116.61
9DD6 HP 312A Yellow Toner Cartridge In Stock £116.61
9DD6 HP 312X High Yield Black Original LaserJet Toner Cartridge In Stock £105.67
9DD6 HP 312A 3-pack Cyan/Magenta/Yellow Original LaserJet Toner Cartridges In Stock £333.18
