This HP Color LaserJet Pro MFP connects the whole office to vibrant colour printing, even on the go. See productivity improve with fast, versatile scanning that can send documents directly to email, network folders, and the cloud.
Print on your terms
Print how and where you want: easily send print jobs wirelessly without a network.Enable touch-to-print convenience from mobile devices.Easily print from smartphone, tablets and notebooks at work, home, or on-the-go; with HP's first Mopria-certified MFP.Share all your printer has to offer – set up, print, and share with Ethernet and wireless connectivity. -
Scan fast, and send securely
Save time and get more done much faster: scan two-sided documents in a single pass, with no missed pages or flipping pages.Control access to walk-up features and easily look up network email addresses, using LDAP connectivity.Scan and send; it's simple. Capture and route digital files directly to the Cloud, email, or network folders. -
Speed up your workflow
Save time and help reduce paper costs, using automatic two-sided printing.Work smarter – access content and print from the Cloud using business apps on the control panel. Quickly launch tasks from the 8.9 cm colour touchscreen.Finish projects fast: use the 50-page automatic document feeder to save time.Just walk up to this MFP and print from or scan to your USB drive, using the easy-access USB port.
- HP Color LaserJet Pro MFP M476dn - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 40000 pages
- Recommended Monthly Volume
- 1000 - 2500 pages
- Max Copying Speed
- Up to 20 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- Up to 300 x 420 dpi (mono) / up to 300 x 420 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 3.5"
- Original Size
- Legal (216 x 356 mm) (max)
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 550 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to folder, scan to network, scan to Cloud
- Power
- AC 230 V
- 41.9 cm x 48.5 cm x 50 cm
- 28.9 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 40000 pages
- 1000 - 2500 pages
- Display Diagonal Size
- 3.5"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, PCLm
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 16.5 sec
- First Print Out Time Colour
- 16.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Fax Resolutions
- Fax Printing Speed
- Up to 20 ppm
- Fax Printing Resolution
- 300 x 300 dpi
- PC Faxing
- Yes (send only)
Fax Machine Features
- Speed Dialing
- 120 station(s)
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax memory backup, delayed sending, fax polling, block fax, save and load speed dials, poll receive, fax activity reports, print fax log
Document & Media Handling
- Max Original Size
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm
- 300 sheets
- 550 sheets
- 50 sheets
- 150 sheets
- ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) , Bypass tray - 50 sheets , Output tray - 150 sheets
- Speed Details
- Printing: up to 21 ppm (Letter A) - B/W normal , Printing: up to 21 ppm (Letter A) - colour normal , Copying: up to 21 ppm (Letter A) - B/W normal , Copying: up to 21 ppm (Letter A) - colour normal , Scanning: up to 17 ppm (A4) - B/W normal , Scanning: up to 13 ppm (A4) - colour normal , Scanning: up to 31 ipm (A4) - B/W duplex , Scanning: up to 11 ipm (A4) - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- LDAP
- Operating System Support
- HP-UX 11.x, SunSoft Solaris 2.5 or later, MS Windows XP SP2 or later, Sun Solaris 8, Sun Solaris 9, MS Windows 7, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows Vista, MS Windows 2000 Server, SuSe Linux 10.3, HP-UX 11i, MS Windows Server 2008, Novell NetWare 5.1, Apple Mac OS X 10.6, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Linux Linpus Desktop 9.4, Linux Linpus Desktop 9.5, Red Hat Linux 7.x or later, SUSE Linux 8.x or later, IBM AIX 3.2.5 or later, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, MS Windows Server 2008 R2 x64 Edition, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, HP-UX 10.20, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, MS Windows Server 2003 SP2 or later, Windows 8.1, Apple Mac OS X 10.9
- Software Included
- Drivers & Utilities, HP Web Jetadmin
- Voltage Required
- AC 230 V
- 397 Watt
- Power Consumption Standby
- 17.6 Watt
- Power Consumption Sleep
- 1.5 Watt
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages , 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 41.9 cm
- 48.5 cm
- 50 cm
- 28.9 kg
- Shipping Width
- 61.1 cm
- Shipping Depth
- 60 cm
- Shipping Height
- 50 cm
- Shipping Weight
- 33.3 kg
- Sound Emission
- 28 dB (operating)
- 15 °C
- 30 °C
- 20 - 70% (non-condensing)
HP 312A Black Toner Cartridge | In Stock | £86.84 |
HP 312A Cyan Toner Cartridge | In Stock | £115.61 |
HP 312A Magenta Toner Cartridge | In Stock | £115.61 |
HP 312A Yellow Toner Cartridge | In Stock | £115.61 |
HP 312X High Yield Black Original LaserJet Toner Cartridge | In Stock | £104.76 |
HP 312A 3-pack Cyan/Magenta/Yellow Original LaserJet Toner Cartridges | In Stock | £330.31 |
