HP M454dn Colour LaserJet Pro Printer
Quicklinx: FBJ2WS00 Mfr#: W1Y44A#B19
Winning in business means working smarter. The HP Color LaserJet Pro M454 printer is designed to let you focus your time where it's most effective-helping to grow your business and staying ahead of the competition.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
  • Built to keep you – and your business – moving forward
    Help decrease the amount of paper used in the office by printing on both sides of the page.Grab pages and go – without waiting. This device wakes up and prints first page out fast.ROAM compatible for easy printing from virtually anywhere.
  • Best-in-class security
    A suite of embedded security features help protect your printer from being an entry point for attacks.Help secure confidential information with optional PIN/Pull printing to retrieve print jobs.Optional HP JetAdvantage Security Manager lets you set configuration policies and validate settings.Thwart potential attacks and take immediate action with instant notification of security issues.
  • Simply designed to uncomplicate your day
    Set up this printer fast and easily manage device settings to help increase overall printing efficiency.Make the most of your office space with a printer that conveniently fits into your work style.Work without delays or messes, with cartridges featuring auto seal removal.
  • Sustainability is smart business
    Avoid frustrating reprints, wasted supplies, and service calls using Original HP toner cartridges.Help save paper right out of the box. The duplex print setting is set at default paper savings mode.Saves up to 11% energy over prior products.Help save energy with HP Auto-on/Auto-off technology.
HP Color LaserJet Pro M454dn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
18.9 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 27 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 27 ppm - color (ISO) - A4 (210 x 297 mm) , Up to 28 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 28 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 49 ppm - black landscape - A5 (148 x 210 mm) , Up to 49 ppm - colour landscape - A5 (148 x 210 mm) , Up to 7 ppm - black portrait - A5 (148 x 210 mm) , Up to 7 ppm - colour portrait - A5 (148 x 210 mm) , Up to 24 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 24 ipm - colour duplex - A4 (210 x 297 mm) , Up to 25 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 25 ipm - colour duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
38400 x 600 dpi
Max Resolution (Colour)
38400 x 600 dpi
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
1.2 GHz
RAM Installed (Max)
512 MB (512 MB)
Flash Memory Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF, URF, PWG
Media Type
Envelopes, labels, plain paper, photo paper, bond paper, recycled paper, punched paper, preprinted paper, postcards, glossy paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Print server
Printer Features
PANTONE calibrated, Instant-on Technology
Android, Microsoft Windows Server 2008 R2 x64 Edition, Apple iOS, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows Server 2008 R2 SP1 (64-bits), Microsoft Windows 7 / 8 / 10, Apple macOS 10.12, Apple macOS 10.13, Apple macOS 10.14
Environmental Standards
EPEAT Silver
1-year warranty
41.2 cm x 46.9 cm x 29.5 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
38400 x 600 dpi
38400 x 600 dpi
HP ImageREt 3600
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
9.7 sec
First Print Out Time Colour
11.3 sec
Language Simulation
Fonts Included
84 x TrueType
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Flash Memory
Flash Memory
256 MB (installed) / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 197 x 273 mm, 76 x 127 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm
Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
Media Weight
60 g/m² - 200 g/m²
Media Weight (lbs)
16 lbs - 52 lbs
300 sheets
Media Feeders
Input tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 52 lbs (max)) , Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 52 lbs (max))
Max Media Capacity
850 sheets
Output Trays Capacity
150 sheets
Duty Cycle
50000 pages
750 - 4000 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP, IPv4
Security Protocols & Features
SSL, Apple Bonjour, TLS, 802.1x, EAP-TLS, PEAP, IPv6 support
1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
FCC Class B certified, FCC Class A certified, Laser Class 1, FCC CFR47 Part 15, CECP, EN 62479:2010, EN 61000-3-3:2013, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 55024:2010+A1:2015, ICES-003 issue 6, CISPR 32:2012, EN 55032:2015 Class B, EN 60825-1:2014, EN 55032:2012 Class B, IEC 60825-1:2014, CISPR 32:2015, RAL-UZ 205, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Power supply - internal
Frequency Required
50/60 Hz
550 watt
Power Consumption Stand by
17 watt
Power Consumption Sleep
0.9 watt
System Requirements Details
HD 2 GB
EPEAT Compliant
EPEAT Silver
Blue Angel
ENERGY STAR
Limited warranty - 1 year
15 °C
30 °C
10 - 80% (non-condensing)
Sound Emission (Idle)
14 dBA
Sound Emission (Operating)
48 dBA
41.2 cm
46.9 cm
29.5 cm
18.9 kg
Width (Shipping)
49.7 cm
Depth (Shipping)
37.9 cm
Height (Shipping)
58.3 cm
Weight (Shipping)
22 kg
FBJ2 HP 415A Black Original LaserJet Toner Cartridge In Stock £71.20
FBJ2 HP 415A Cyan Original LaserJet Toner Cartridge In Stock £95.81
FBJ2 HP 415A Yellow Original LaserJet Toner Cartridge In Stock £92.14
FBJ2 HP 415A Magenta Original LaserJet Toner Cartridge In Stock £92.14
FBJ2 HP 415X High Yield Black Original LaserJet Toner Cartridge In Stock £145.61
FBJ2 HP 415X High Yield Cyan Original LaserJet Toner Cartridge In Stock £198.94
FBJ2 HP 415X High Yield Yellow Original LaserJet Toner Cartridge In Stock £198.94
FBJ2 HP 415X High Yield Magenta Original LaserJet Toner Cartridge In Stock £198.94
FBJ2 HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.62
