HP LTO4 Ultrium WORM Automation Bar Code Labels (110 pack)
Quicklinx: 86GSWS00 Mfr#: Q2010A
Type: Other
£115.32 ex VAT
£138.38 inc VAT
HPE LTO Ultrium, Super DLT and DLTtape IV Bar Code Label Packs provide an easy-to-use solution to the aggravation of bar coding. Under constant pressure to deliver quality of service with limited resources, the last thing IT managers should be worrying about is why their in-house bar code labels aren't working properly or whose turn it is to operate (or run) the departmental label printer. Each HPE label pack of consecutively numbered bar codes contains 100 data labels and 10 cleaning cartridge labels. No two pack sequences are ever identical to avoid data integrity issues in archives. HPE Bar Code Label Packs will be available from most resellers that stock HPE brand media. Finally, HPE Bar Code Label Packs have been fully tested to guarantee performance in demanding automation environments, so unlike cheaper alternatives, users can be certain that their backups will never be disrupted by bar code quality issues.
  • Reliable Offline Medium that Creates an Air Gap to Keep Data Out of the Reach of Cybercriminals
    Agencies such as the US FBI recommend keeping data offline. This is because tapes that are stored offline are disconnected from the network and are out of reach of sophisticated criminals who use digital networks to strike at companies to encrypt both their primary data and their backups.Built-in AES 256-bit encryption (LTO-5 to LTO-9) allows you to provide additional security for data stored on tape. With LTO encryption (strengthened by the option to use WORM cartridges), even if tapes were to fall into the wrong hands, your data would be protected from unauthorized access.HPE LTO Ultrium cartridge memory chip delivers faster access time and enhanced media monitoring.First time restore ensured with fewer media failures and disrupted backups, regardless of duty cycle or environmental conditions.
  • Lowest Total Cost of Ownership for Long-term Archiving
    According to a white paper from ESG, 'The Economic Benefits of HPE StoreEver as Active Archival Storage', published in August 2020, LTO tape technology is over 80% less expensive across a 10-year period, than either all-disk or all-cloud solutions for a 1 PB archive growing at 10% per annum.Standardizing on HPE LTO Ultrium delivers the capacity to meet shrinking backup windows, industry-standard, AES 256-bit encryption (IEEE1619.1), and interchangeable read-write (RW) or WORM media; without extra space or IT resource overhead.Open standard technology helps ensure compatibility across product generations and gives you more choice. HPE LTO Ultrium cartridges are available as custom labeled or non-custom labeled.HPE brand qualification test procedures (load/unload, shoeshine, drop testing and environmental stress testing).This ensures maximum reliability for restoring your data.HPE offers a limited lifetime warranty for HPE LTO Ultrium cartridges, including up to 30 years archival life, if stored at the recommended storage conditions. This ensures businesses can meet the ever-increasing demands of regulation for data retention and archiving.
  • Highest Capacity and Performance of any Comparable Tape Technology
    HPE LTO-9 Ultrium data cartridges can write or read data at a blistering native 1.44 TB/hour, storing, encrypting, and protecting up to 45 TB* on a single cartridge, making it ideal for large-scale, 24x7, mission-critical IT environments (*capacity assumes 2.5:1 compression).A 35% increase in the number of tracks and a 3% increase in bit density has permitted a capacity increase from 30 TB for LTO-8 to 45 TB for LTO-9. From 2,176 tracks for LTO-6 to 8,960 tracks for 9th generation HPE LTO-9 Ultrium 45 TB cartridges (assuming 2.5:1 compression) – an improvement of 311%
  • Ultra-reliable Storage Medium
    Tape is more reliable than enterprise SATA disk, with a bit error rate (BER) of 1x10 to the power of 19 for LTO-8 versus 1x10 to the power of 15 for enterprise SATA HDD's. That's a difference in reliability of four orders of magnitude–e.g. tape is 10,000 times more reliable than enterprise SATA HDD.Estimated data loss over 10 years for 1 Exabyte archive is 1.1 Petabytes for HDD compared to only 7.4 Terabytes for tape.HPE brand qualification test procedures (load/unload, shoeshine, drop testing and environmental stress testing) go far beyond what is required for the HPE LTO Ultrium. This ensure utmost reliability for restoring your data.Superior 'smart grabber' mechanism and mechanical interlock to prevent the leader pin from being pulled inside the tape housing. Sensors detect proper connection and prevent leader loss that would ruin the tape. Simplified tape path to reduce wear, tear, and build-up of debris–crucial in automation.User write-on labels are no longer included with A and W SKU's.
HPE Ultrium 4 WORM Bar Code Label Pack - bar code labels
Bar code labels
HPE MSL2024, MSL4048; 1/8 G2 Tape Autoloader; LTO-4 Ultrium; StorageWorks ESL 712e, MSL2024, MSL4048, MSL6026, MSL8096, Ultrium 960; StorageWorks 1/8 G2 Tape Autoloader; 1/8 Tape Autoloader; StorageWorks Enterprise Modular Library E-Series 103e; StoreEver Ultrium 1840
Bar code labels
HPE MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL4048 Ultrium 1760 , HPE 1/8 G2 Tape Autoloader Ultrium 1760 , HPE LTO-4 Ultrium 1760 SAS Drive Upgrade Kit, 1760 SCSI Drive Upgrade Kit , HPE StorageWorks ESL 712e, MSL2024 Ultrium 448, MSL4048 Ultrium 448, MSL6026, MSL8096 Ultrium 960, Ultrium 960 Drive Upgrade Kit , HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 920 , HPE StorageWorks 1/8 Tape Autoloader Ultrium 448, Ultrium 960 , HPE StorageWorks Enterprise Modular Library E-Series 103e Base Library , HPE StoreEver Ultrium 1840 Drive Upgrade Kit
86GS HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge In Stock £35.59
86GS HPE Ultrium Data Cart LTO 5 In Stock £25.80
86GS HPE Ultrium RW Data Cartridge LTO Ultrium 7 6TB 15TB In Stock £51.30
Type: Other
Brand: HP
