HP LD4200TM TOUCH DIGITAL SIGNAGE DISPLAY
Quicklinx: 79LBWS00 Mfr#: WD017AA
  • 1080p
HP LD4200tm 42-inch Widescreen LCD Interactive Digital Signage Display WD017AA
  • Recognizes multiple touch inputs
    Clear glass screen with infrared technology recognizes multi-touch inputs while a full HD native resolution (1920 x 1080) provides stunning video, graphics or text in both bright and dim lighting.
  • Simple to set up
    Quickly connect with a HID-compliant plug-and-play USB. Take advantage of simple set up with one USB cable for power and touch-enabled capabilities.
  • Versatile for any business
    This sleek black display is built to fit in trendy indoor environments, such as retail, hospitality, airports, bus terminals, educational settings, restaurants, conference rooms, stock exchanges and more.
  • Reliable and flexible
    The HP LD4200tm is fully tested and built to run 24/7 while maintaining longevity. Mount it vertically or horizontally on a wall with the VESA mounting pattern or place it on a stand to fit your environment.
HP LD4200tm 42" LCD flat panel display - Full HD
LCD flat panel display with touchscreen
Diagonal Class
42"
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15), HDMI
HDCP Compatible
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Remote control
Microsoft Certification
Compatible with Windows 7
Voltage
220 Watt
99.9 cm x 11.9 cm x 59.2 cm
27 kg
3-year warranty
220 Watt
Diagonal Class
42"
Combined With
Touchscreen
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15), HDMI
HDCP Compatible
Dimensions
Without stand
99.9 cm
11.9 cm
59.2 cm
27 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Image Contrast Ratio
1000:1
Dynamic Contrast Ratio
3000:1
Brightness
500 cd/m²
Colour Gamut
72% (NTSC)
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.4845 x 0.4845mm
Response Time
9 ms
V-Sync Rate at Max Res.
60 Hz
Max V-Sync Rate
76 Hz
Max H-Sync Rate
83 kHz
Display Menu Language
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese, Korean
Backlight Life
50,000 hour(s)
Stands & Mounts
Flat Panel Mount Interface
Video Features
Input Video Formats
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Connector Type
VGA input , HDMI input , 2 x component video input , Composite video input , S-Video input , VGA output , Serial , 4 x audio input , Audio input , Composite video output
RoHS, WEEE
Power supply - internal
Input Voltage
Power Consumption Stand by / Sleep
1 Watt
Limited warranty - 3 years
Dimensions & Weight Details
Panel without stand - 99.9 cm x 11.9 cm x 59.2 cm x 27 kg , Panel with stand - 99.9 cm x 29.3 cm x 66.7 cm x 30.2 kg
