HP LasetJet Managed MFP M725dnm
Quicklinx: CP0NWS00 Mfr#: L3U63A#B19
Ramp up your business efficiency and print in sizes up to A3 with ease. HP Managed MFPs and printers are optimized for managed environments. Offering increased monthly page volumes and fewer interventions, this portfolio of products can help reduce printing and copying costs.
Expand your options with sharp A3 printing
Empower your teams to do more – print, scan, copy and fax on paper sizes up to A3 – from a desktop-sized MFP.
Stay focused on work – paper capacity up to 4,600 sheets and high-capacity cartridges limit interruptions.
Get impressive document quality with near edge-to-edge printing and a convenient, built-in stapler.
Print what you need, even on the go – from your smartphone or tablet – using HP ePrint or Apple AirPrint™.
Quicken your business pace
Streamline tasks – print, scan, copy and fax projects directly at the MFP's large colour touchscreen.
Save time by launching one-touch workflows with HP Quick Sets.
Get just the results you need – using touchscreen controls to preview, edit and reorder scans at the device.
Easily send scanned files to a fax, folder, email or USB. Print right from a memory device via the USB port.
Manage and protect your fleet for the long run
Simplify fleet management using industry-leading tools such as HP Web Jetadmin and reliably safeguard devices.
Safeguard data – at rest or in transit – with an encrypted hard drive, user authentication and security features.
Add security tools – such as card and badge readers – via the hardware integration pocket.
Extend the capabilities of workteam print environments, using a rich array of easy-to-integrate solutions.
Save energy and reduce your environmental impact
Reduce energy use with HP Auto-On/Auto-Off Technology, and conserve power with Instant-on Technology.
Save paper and cut costs, using automatic two-sided printing.
Easily recycle Original HP LaserJet toner cartridges through HP Planet Partners.
  • Expand your options with sharp A3 printing
    Empower your teams to do more - print, scan, copy and fax on paper sizes up to A3 - from a desktop-sized MFP. Stay focused on work - paper capacity up to 4,600 sheets and high-capacity cartridges limit interruptions. Get impressive document quality with near edge-to-edge printing and a convenient, built-in stapler. Print what you need, even on the go - from your smartphone or tablet - using HP ePrint or Apple AirPrint.
  • Quicken your business pace
    Streamline tasks - print, scan, copy and fax projects directly at the MFP's large color touchscreen. Save time by launching one-touch workflows with HP Quick Sets. Get just the results you need - using touchscreen controls to preview, edit and reorder scans at the device. Easily send scanned files to a fax, folder, email or USB. Print right from a memory device via the USB port.
  • Manage and protect your fleet for the long run
    Simplify fleet management using industry-leading tools such as HP Web Jetadmin and reliably safeguard devices. Safeguard data - at rest or in transit - with an encrypted hard drive, user authentication and security features. Add security tools - such as card and badge readers - via the hardware integration pocket. Extend the capabilities of workteam print environments, using a rich array of easy-to-integrate solutions.
  • Save energy and reduce your environmental impact
    Reduce energy use with HP Auto-On/Auto-Off Technology, and conserve power with Instant-on Technology. Save paper and cut costs, using automatic two-sided printing.
HP LaserJet Managed MFP M725dnm - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
375000 pages
Recommended Monthly Volume
5000 - 40000 pages
Max Copying Speed
Up to 41 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 41 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 dpi
Display
8"
Original Size
68 x 148 mm (min) - A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76.2 x 127 mm (min) - 312 x 469.9 mm (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, vellum paper, card stock, light-weight paper, preprinted paper
Standard Media Capacity
600 sheets
Max Media Capacity
4600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host (internal), USB 2.0 host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to network, Hardware Integration Pocket, Foreign Interface Harness (FIH)
AC 230 V (50/60Hz)
61.4 cm x 64.9 cm x 60.9 cm
54.11 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Laser - monochrome
375000 pages
5000 - 40000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
1.5 GB
Copying
Max Copying Speed
Up to 41 ppm
Up to 600 x 600 dpi
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Up to 41 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.4, PCL 5
Automatic Duplexing
First Print Out Time B/W
10 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
68 x 148 mm
Max Original Size
A3 (297 x 420 mm)
Original Type
Sheets
100 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A3/Ledger
Min Media Weight
45 g/m²
Max Media Weight
199 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 76.2 x 127 mm, JIS B6 (128 x 182 mm), 297 x 363 mm, 312 x 469.9 mm, 297 x 431 mm
600 sheets
Max Media Capacity
4600 sheets
100 sheets
250 sheets
RADF - 100 sheets size: 68 x 148 mm - A3 (297 x 420 mm) weight: 45 g/m² - 199 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - 312 x 469.9 mm weight: 60 g/m² - 199 g/m² , Input tray - 250 sheets size: A5 (148 x 210 mm) - 297 x 363 mm weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: A5 (148 x 210 mm) - 297 x 431 mm weight: 60 g/m² - 120 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 41 ppm (A4) - B/W , Printing: up to 28 ipm (A4) - B/W duplex , Printing: up to 20 ppm (A3) - B/W , Copying: up to 41 ppm (A4) , Scanning: up to 50 ppm - B/W , Scanning: up to 30 ppm - colour , Scanning: up to 19 ipm - B/W duplex , Scanning: up to 14 ipm - colour duplex
2 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host (internal)
Security Protocols & Features
Kerberos, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP, WPA2-Enterprise
Operating System Support
MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 (32/64-bits)
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
890 Watt
Power Consumption Standby
39 Watt
Power Consumption Sleep
6.5 Watt
Consumables Included
1 x Cartridge (black) - up to 10000 pages
EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:1998 + A1 + A2, EMC 2004/108/EC, EN55022:2010 Class A, CISPR 22:2008
ENERGY STAR Certified
Limited warranty - 1 year - on-site
61.4 cm
64.9 cm
60.9 cm
54.11 kg
Shipping Width
76 cm
Shipping Depth
74.5 cm
Shipping Height
83.2 cm
Shipping Weight
68.6 kg
Sound Emission
54 dBA (operating)
10 °C
32.5 °C
30 - 70%
