HP LaserJet Pro MFP M428fdw Mono Multifunction Printer
Quicklinx: FFL4WS00 Mfr#: W1A30A#B19
Winning in business means working smarter. The HP LaserJet Pro MFP M428 is designed to let you focus your time where it's most effective – growing your business and staying ahead of the competition.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
HP LaserJet Pro MFP M428fdw - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 38 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 38 ppm
Max Printing Resolution
Up to 4800 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
102 x 152 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, light-weight paper, punched paper, preprinted paper
Standard Media Capacity
350 sheets
Max Media Capacity
900 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, save to network folder, scan to Cloud, Instant-on Technology, HP Auto-On/Auto-Off Technology
AC 230 V (50/60Hz)
42 cm x 39 cm x 32.3 cm
12.6 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Printer Fonts
TrueType x 84
Fax Type
Plain paper
Printing Technology
Laser - monochrome
80000 pages
750 - 4000 pages
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 38 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Copying Features
2-up, ID Card Copy, collation copy, margin erase, resize
Printing
Max Printing Speed
Up to 38 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, URF, PWG
Image Enhancement Technology
HP FastRes 1200, HP ProRes 1200, HP ProRes 600
Automatic Duplexing
First Print Out Time B/W
6.3 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 400 pages
PC Faxing
Yes (send only)
Fax Machine Features
Speed Dialing
120 station(s)
Telephone / Fax Switch
Broadcast Transmission
119 stations
Delayed Transmission
Remote Fax Retrieval (Polling)
Fax forwarding, activity report, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax memory backup, block fax, print fax log, billing codes
Document & Media Handling
Min Original Size
102 x 152 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
175 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
46.6 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 197 x 273 mm, 76.2 x 127 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm, 104.9 x 148.59 mm
350 sheets
Max Media Capacity
900 sheets
100 sheets
150 sheets
ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²; weight (lbs): 16 lbs - 32 lbs , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 175 g/m²; weight (lbs): 16 lbs - 46.6 lbs , Input tray - 250 sheets size: 104.9 x 148.6 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²; weight (lbs): 16 lbs - 32 lbs , Output tray - 150 sheets
Speed Details
Printing: up to 38 ppm (A4) - B/W (ISO) , Printing: up to 40 ppm (Letter A) - B/W (ISO) , Printing: up to 31 ipm (A4) - B/W duplex , Printing: up to 33 ipm (Letter A) - B/W duplex , Copying: up to 38 ppm (A4) - B/W normal , Copying: up to 40 ppm (Letter A) - B/W normal , Scanning: up to 29 ppm (A4) - B/W normal , Scanning: up to 46 ipm (A4) - duplex normal , Scanning: up to 46 ipm (A4) - B/W normal , Printing: up to 63 ppm (A5) - B/W landscape , Printing: up to 14 ppm (A5) - B/W portrait
2 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, SSL, Apple Bonjour, LEAP, WEP, TLS, WPA, WPA2, 802.1x, TKIP, AES, WPS, Wi-Fi Direct, EAP-TLS, PEAP, WPA2-Enterprise, IPv6 support, SNMP 3
Operating System Support
UNIX, Red Hat Linux 8.0, Red Hat Linux 9.0, Ubuntu Linux 10.04, Red Hat Enterprise Linux 5, Mandriva 2010, Red Hat Enterprise Linux 6, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Fedora 17, Fedora 18, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, MS Windows XP 64-bit Edition SP3 or later, Apple Mac OS X 10.9, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Linux Mint 15, Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Ubuntu Linux 13.10, Windows 10 (32/64-bits), SuSe Linux 12.2, SuSe Linux 12.3, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, MEPIS 6.0 or later, Slackware Linux 9.0 or later, gOS 8.04.1, IGOS 1.0, Linpus Linux 9.4, Linpus Linux 9.5, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0 - 7.6, Mandriva 2011, MEPIS 6.5, MEPIS 7.0, MEPIS 8.0, PCLinuxOS 2006, PCLinuxOS 2007, PCLinuxOS 2008, PCLinuxOS 2009, Red Hat Enterprise Linux 7, Slackware Linux 9.1, Slackware Linux 10.0, Slackware Linux 10.1, Slackware Linux 10.2, Slackware Linux 11.0, Slackware Linux 12.0, Slackware Linux 12.1
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
510 watt
Power Consumption Standby
7.5 watt
Power Consumption Sleep
0.9 watt
First Copy Out Time B/W
7.2 sec
FCC Class B certified, FCC Class A certified, CSA, UL, TUV, GS, NOM, CCC, FCC CFR47 Part 68, Laser Class 1, FCC CFR47 Part 15, KCC, FCC CFR47 Part 15 C, S Mark, KC, CECP, EN 62479:2010, BIS, ETSI ES203 021, EN 61000-3-3:2013, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, IEC 62311:2007, EN 55024:2010+A1:2015, EN 301 893, RSS-247 Issue 1, FCC CFR47 Part 15 E, ICES-003 issue 6, CISPR 32:2012, EN 300 328 V2.1.1, EN 55032:2015 Class B, EN 301 489-1 V2.1.1, EN 60825-1:2014, EN 55032:2012 Class B, IEC 60825-1:2014, EN 301 489-17 V3.1.1, CISPR 32:2015, RAL-UZ 205, RED 2014/53/EU, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
42 cm
39 cm
32.3 cm
12.6 kg
Shipping Width
49.7 cm
Shipping Depth
39.8 cm
Shipping Height
49 cm
Shipping Weight
15.5 kg
Sound Emission
53 dBA (operating)
15 °C
32.5 °C
10 - 80% (non-condensing)
Ink (3)
FFL4 HP 59A Black Original LaserJet Toner Cartridge In Stock £88.22
FFL4 HP 59X High Yield Black Original LaserJet Toner Cartridge In Stock £184.77
FFL4 HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.62
Other bundles (1)
FFL4 HP 550 sheet paper tray for LaserJet Pro M402d, M402n, M402dn In Stock £100.51
