HP Color LaserJet Pro MFP M277dw Colour Laser - Fax / copier / printer / scanner
- Print, scan, copy, with one compact device
- Fast two-sided printing built-in
- Fast FPOT from ready mode
- HP Auto-On/Auto-Off Technology
- 6.9 cm touchscreen
Fast speeds, low energy use
Print, scan, copy with a compact multifunction laser printer that fits into tight workspaces.Print at the pace of business with fast two-sided printing – first pages are ready in as fast as 7 seconds.Help save energy with HP Auto-On/Auto-Off Technology.Easily scan files directly to email, USB, and network folders with preloaded business apps. -
Mobile printing made simple
Print from iPhone and iPad with AirPrint , which automatically scales jobs to the correct paper size.Print with the ease of sending an email, right from a smartphone, tablet, or notebook, using HP ePrint.Send jobs from your smartphone, tablet, or PC to any company printer, using Google Cloud Print 2.0. -
Manage company-wide printing with confidence
Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency.Identify new devices and gain insight into printing with HP Web Jetadmin remote discovery and monitoring.Employ policy-based, fleet-wide protection features, using optional HP JetAdvantage Security Manager. -
HP quality – print after print
Produce sharp text, bold blacks, and crisp graphics with precision black toner.Don't be fooled by cartridges that mimic Original HP. Help ensure you're getting the quality you paid for.Print over 2x more pages than standard cartridges, using optional Original HP high-yield toner cartridges.Get more pages than ever before, and track remaining pages to help ensure you get what you paid for.
- HP LaserJet Pro MFP M227sdn - multifunction printer - B/W
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Max Copying Speed
- Up to 28 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 28 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper, light-weight paper, preprinted paper, postcards
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 10 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Office Machine Features
- Instant-on Technology
- Power
- AC 230 V (50/60Hz)
- 40.3 cm x 40.74 cm x 31.15 cm
- 9.4 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Laser - monochrome
- 30000 pages
- 250 - 2500 pages
- Display
- 2 lines
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Up to 28 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy
Printing
- Up to 28 ppm
- Printer Drivers / Emulations
- PCL 6, PCL 5c, PDF, PCLm
- Image Enhancement Technology
- HP FastRes 1200, HP ProRes 1200
- First Print Out Time B/W
- 6.4 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, 76 x 187 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm)
- 250 sheets
- 250 sheets
- 10 sheets
- 150 sheets
- Input tray - 250 sheets size: 76 x 187 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets , ADF - 35 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 75 g/m² , Bypass tray - 10 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Speed Details
- Printing: up to 47 ppm (A5) - B/W fast , Printing: up to 28 ppm (A4) - B/W normal , Printing: up to 6 ppm (A5) - B/W best , Scanning: up to 15 ppm (A4) - B/W normal , Copying: up to 28 ppm (A4) - B/W normal , Copying: up to 18 ppm (A4) - B/W duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Apple Bonjour
- Operating System Support
- UNIX, Linux, Apple Mac OS X 10.9, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
- Software Included
- Drivers & Utilities
- Voltage Required
- 475 watt
- Power Consumption Standby
- 4.5 watt
- Power Consumption Sleep
- 1 watt
- Consumables Included
- 1 x toner cartridge (black) - up to 1600 pages , 1 x drum - up to 23000 pages
- ENERGY STAR Certified
- Blue Angel Compliant
- 40.3 cm
- 40.74 cm
- 31.15 cm
- 9.4 kg
- Shipping Width
- 49 cm
- Shipping Depth
- 39.2 cm
- Shipping Height
- 49 cm
- Shipping Weight
- 13.2 kg
Ink (3)
HP 30A - black - original - LaserJet - toner cartridge ( CF230A ) | In Stock | £58.89 |
HP 32A Original Drum for LaserJet Pro | In Stock | £79.20 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £16.62 |
Other bundles (4)
HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment | In Stock | £40.97 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment | In Stock | £48.86 |
HP Care Pack Standard Exchange Extended Service Agreement 2 Years Shipment | In Stock | £23.59 |
HP 2y Nbd Exch Cons Laserjet MFP-E SVC -HP Consumer Laserjet MF | In Stock | £29.49 |
