HP LaserJet Pro MFP M227fdw (28 ppm, A4, USB, Ethernet,Wi-Fi, PRINT/SCAN/COPY/FAX, duplex)
Get more pages, performance, and protection from an HP LaserJet Pro MFP powered by JetIntelligence Toner cartridges. Set a faste rpace for your business: print two-sided documents, plus scan, copy, fax, and manage to help maximise efficiency.
Fast speeds, low energy use
- Print, scan, copy, and fax with a compact multifunction laser printer that fits in to tight workspaces.
- Print at the pace of business with fast two-sided printing– first pages are ready in as fast as 7 seconds.
- Help save energy with HP Auto-On/Auto-Off Technology.
- Tackle tasks and scan to email, USB, and network folders from the 6.9cm colour touchscreen.
Mobile printing made simple
- Print from iPhone® and iPad® with AirPrint®, which automatically scales jobs to the correct papersize.
- Print from your mobile device with Wi-Fi Direct® and NFC touch-to-print technology– no network needed.
- Print with the ease of sending an email, right from a smartphone, tablet, or notebook, using HPe Print.
- Send jobs from yoursmartphone,tablet,orPCtoanycompanyprinter,using Google Cloud Print™2.0.
Managecompany-wideprintingwithconfidence
- Centralise control of your printing environment with HP WebJetadmin– and help build business efficiency.
- Identify new devices and gain insight into printing with HP WebJetadmin remote discovery and monitoring.
- Employ policy-based, fleet-wide protection features, using optional HP JetAdvantage Security Manager.
HP quality–print after print
- Produce sharp text, bold blacks, and crisp graphics with precision black toner.
- Don’t be fooled by cartridges that mimic Original HP. Help ensure you’re getting the quality you paid for.
- Print over 2x more pages than standard cartridges, using optional Original HP high-yield tonercartridges.
- Get more pages than ever before, and track remaining pages to help ensure you get what you paid for.
- HP LaserJet Pro MFP M227fdw - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Max Copying Speed
- Up to 28 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 28 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 1200 dpi
- Display
- 2.7"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper, light-weight paper, preprinted paper, postcards
- Standard Media Capacity
- 260 sheets
- Max Media Capacity
- 260 sheets
- Bypass Feeder Capacity
- 10 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, save to network folder, scan to Cloud, Instant-on Technology
- Power
- AC 230 V (50/60Hz)
- 40.3 cm x 40.74 cm x 31.15 cm
- 9.4 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - monochrome
- 30000 pages
- 250 - 2500 pages
- Display Diagonal Size
- 2.7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Up to 28 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy
Printing
- Up to 28 ppm
- Printer Drivers / Emulations
- PCL 6, PCL 5c, PDF, PCLm
- Image Enhancement Technology
- HP FastRes 1200, HP ProRes 1200
- First Print Out Time B/W
- 6.8 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 1000 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 120 station(s)
- Delayed Transmission
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), poll receive
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, 76 x 187 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm)
- 260 sheets
- 260 sheets
- 10 sheets
- 150 sheets
- Input tray - 250 sheets size: 76 x 187 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets , ADF - 35 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 75 g/m² , Bypass tray - 10 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Speed Details
- Printing: up to 47 ppm (A5) - B/W fast , Printing: up to 28 ppm (A4) - B/W normal , Printing: up to 6 ppm (A5) - B/W best , Scanning: up to 15 ppm (A4) - B/W normal , Copying: up to 28 ppm (A4) - B/W normal , Copying: up to 18 ppm (A4) - B/W duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Apple Bonjour
- Operating System Support
- UNIX, Linux, Apple Mac OS X 10.9, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
- Software Included
- Drivers & Utilities
- Voltage Required
- 475 watt
- Power Consumption Standby
- 4.5 watt
- Power Consumption Sleep
- 1 watt
- Consumables Included
- 1 x toner cartridge (black) - up to 1600 pages , 1 x drum - up to 23000 pages
- ENERGY STAR Certified
- Blue Angel Compliant
- 40.3 cm
- 40.74 cm
- 31.15 cm
- 9.4 kg
- Shipping Width
- 49 cm
- Shipping Depth
- 39.2 cm
- Shipping Height
- 49 cm
- Shipping Weight
- 13.2 kg
Ink (3)
HP 30A - black - original - LaserJet - toner cartridge ( CF230A ) | In Stock | £59.18 |
HP 32A Original Drum for LaserJet Pro | In Stock | £79.59 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £16.64 |
Other bundles (4)
HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment | In Stock | £40.97 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment | In Stock | £48.86 |
HP Care Pack Standard Exchange Extended Service Agreement 2 Years Shipment | In Stock | £23.59 |
HP 2y Nbd Exch Cons Laserjet MFP-E SVC -HP Consumer Laserjet MF | In Stock | £29.49 |
