HP LaserJet Pro MFP M182n Colour Laser Multifunction Printer
Quicklinx: FV46WS00 Mfr#: 7KW54A#B19
An efficient MFP for high-quality colour and productivity. Save time with Smart Tasks in HP Smart app, and print and scan from your phone. Get security essentials to help maintain privacy and control.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
  • Freedom to work anywhere
    Get easy printing and scanning from your mobile device, with HP Smart – best-in-class mobile print app.Eliminate steps in repetitive tasks with customisable shortcuts, with Smart Tasks in HP Smart app.Organise documents 50% faster with Smart Tasks – first mobile print app that automates scanning tasks.Get notifications when printing, scanning, or copying from your mobile device, using HP Smart app.
  • Trusted HP quality and performance
    Get high-quality colour and peak printing performance with Original HP Toner cartridges with JetIntelligence.Breeze through tasks with a 35-page automatic document feeder.Get quick and easy copying and faxing directly at the control panel.Help save energy with HP Auto-On/Auto-Off Technology.
  • Essential security
    Security essentials to help maintain privacy and control, including basic encryption and password protection.Easily share resources – access and print with Ethernet networking.
HP Color LaserJet Pro MFP M182n - multifunction printer - colour
Multifunction printer
Multilingual / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
150 - 1500 pages
Max Copying Speed
Up to 16 ppm (mono) / up to 16 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Scanning
1200 x 1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN
AirPrint Enabled
Office Machine Features
Scan to folder, scan to PDF
AC 230 V (50/60Hz)
42 cm x 38 cm x 29.26 cm
15.7 kg
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified, Blue Angel
1-year warranty
Printer Fonts
TrueType x 84
Printing Technology
Laser - colour
30000 pages
150 - 1500 pages
Display Features
7 segment LCD display with icons
USB 2.0, LAN
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Hard Disk Drive
128 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, PCLm, PCLms, URF, PWG
Image Enhancement Technology
HP ImageREt 3600
First Print Out Time B/W
11.8 sec
First Print Out Time Colour
13.8 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 127 x 203 mm, 102 x 152 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 105 x 241 mm, 197 x 273 mm, 76 x 127 mm, 216 x 340 mm, 215.9 x 330.2 mm, 210 x 148 mm, 98 x 191 mm, 110 x 220 mm, JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm, 210 x 299 mm, 100 x 147 mm, 147 x 200 mm, 216 x 330 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
150 sheets
100 sheets
Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 16 ppm (A4) - B/W (ISO) , Printing: up to 16 ppm (A4) - colour (ISO) , Printing: up to 27 ppm (A5) - B/W landscape , Printing: up to 21 ppm (A5) - colour landscape , Printing: up to 5 ppm (A5) - B/W portrait , Printing: up to 5 ppm (A5) - colour portrait , Copying: up to 16 ppm (A4) - B/W normal , Copying: up to 16 ppm (A4) - colour normal , Scanning: up to 15 ppm (A4) - B/W normal , Scanning: up to 8 ppm (A4) - colour normal
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
SSL, Apple Bonjour, TLS, IPv6 support, SNMP 3
Operating System Support
UNIX, Linux, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), macOS 10.12, macOS 10.13, macOS 10.14, macOS 10.15
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
313 watt
Power Consumption Standby
7.4 watt
Power Consumption Sleep
0.7 watt
Warm-Up Time
59 sec
First Copy Out Time B/W
12.2 sec
First Copy Out Time Colour
17.9 sec
TUV GS, EAC, EN 62479:2010, EN 61000-3-3:2013, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 55024:2010+A1:2015, EN 55032:2012, IEC/EN 60825-1:2014 Class 1, CISPR 32:2012, CISPR 32:2015, EN 55032:2015+AC:2016 Class B, Mercury-free, DE-UZ 205, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
42 cm
38 cm
29.26 cm
15.7 kg
Shipping Width
49.7 cm
Shipping Depth
37.9 cm
Shipping Height
46.6 cm
Shipping Weight
18.4 kg
Sound Emission
16 dBA (idle) / 49 dBA (operating)
10 °C
32.5 °C
30 - 70%
Ink (4)
FV46 HP 216A Black Original LaserJet Toner Cartridge In Stock £41.57
FV46 HP 216A Cyan Original LaserJet Toner Cartridge In Stock £45.34
FV46 HP 216A Yellow Original LaserJet Toner Cartridge In Stock £44.81
FV46 HP 216A Magenta Original LaserJet Toner Cartridge In Stock £44.81
Other bundles (4)
FV46 HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment In Stock £40.43
FV46 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £48.51
FV46 HP Care Pack Standard Exchange Extended Service Agreement 2 Years Shipment In Stock £21.99
FV46 HP 2y Nbd Exch Cons Laserjet MFP-E SVC -HP Consumer Laserjet MF In Stock £27.47
