Get blazing fast printing speeds, high-volume scanning, and easy management tools with LaserJet Pro.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Large workteam solution
Support your dynamic workteam with this high-speed smart printer, ideal for up to 10 users. -
HP Pro-class print speed
Step up your workflow. HP Pro-class print speed reaches up to 42 ppm to meet high-demand environments. -
Dual-sided scanning
Scan both sides with a single pass. Dual-sided scanning allows your users to get more done in less time. -
Simple shortcuts
Do more in fewer steps. Simple shortcuts allow your employees to complete common tasks with just a touch. -
HP Smart
Get productivity in the palm of your hand. Print, scan, and save time with Shortcuts from HP Smart. -
HP Web Jetadmin
Centralize print management. HP Web Jetadmin makes it easy with its suite of features.
- HP LaserJet Pro MFP 4102fdn - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Max Copying Speed
- Up to 38 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Up to 4800 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 196 dpi, 300 x 300 dpi, 203 x 98 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.7"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, postcards, plain paper, light-weight paper, heavy-weight paper, bond paper, coloured paper, letterheaded paper, preprinted paper, prepunched paper, recycled paper, labels
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 900 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Interface
- Gigabit LAN, USB, USB host, USB 2.0
- AirPrint Enabled
- Office Machine Features
- HP Auto-On/Auto-Off Technology, Instant-on Technology, N-Up printing, ECO Mode, HP Instant Ink, JetIntelligence Cartridge Technology, Mopria certified, print from mobile devices, scan to e-mail, scan to PDF, scan to USB host, scan to folder, scan to Cloud, Private print
- Power
- AC 230 V (50/60Hz)
- 42 cm x 39 cm x 32.3 cm
- 12.6 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Printer Fonts
- TrueType x 84
- Fax Type
- Plain paper
- Laser - monochrome
- 80000 pages
- 750 - 4000 pages
- Display Diagonal Size
- 2.7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Up to 38 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- ID Copy, resize, 2-up, collation copy, 2-sided copy orientation change, quality adjustment
Printing
- Up to 40 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PDF, PostScript 3, PWG, URF
- Image Enhancement Technology
- HP FastRes 1200, HP ProRes 1200
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 400 pages
- Fax Printing Speed
- Up to 10 ppm
- PC Faxing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 53 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), 102 x 152 mm, Executive (184 x 267 mm), Oficio (216 x 343 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), JIS B5 (182 x 257 mm), 195 x 270 mm, 184 x 260 mm, 197 x 273 mm, JIS B6 (128 x 182 mm), Statement (139.7 x 215.9 mm), 100 x 150 mm
- Supported Envelope Sizes
- Japanese postcard (100 x 148 mm), Japanese Postcard Double (148 x 200 mm), US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm), International B5 (176 x 250 mm), International C5 (162 x 229 mm), International DL (110 x 220 mm)
- 350 sheets
- 900 sheets
- 150 sheets
- Input tray - 100 sheets weight: 60 g/m² - 200 g/m²; weight (lbs): 16 lbs - 53 lbs , Input tray - 250 sheets weight: 60 g/m² - 120 g/m²; weight (lbs): 16 lbs - 32 lbs , Output tray - 150 sheets , ADF - 50 sheets weight: 60 g/m² - 120 g/m²; weight (lbs): 16 lbs - 32 lbs
- Speed Details
- Scanning: up to 31 ppm (Letter A) - B/W normal , Scanning: up to 29 ppm (A4) - B/W normal , Scanning: up to 49 ipm (Letter A) - B/W normal , Scanning: up to 21 ppm (Letter A) - colour normal , Scanning: up to 36 ipm (Letter A) - colour normal , Scanning: up to 20 ppm (A4) - colour normal , Scanning: up to 34 ipm (A4) - colour normal , Printing: up to 42 ppm (Letter A) - B/W (ISO) , Printing: up to 40 ppm (A4) - B/W (ISO) , Printing: up to 63 ppm (A5) - B/W landscape , Printing: up to 36 ipm (Letter A) - B/W duplex , Printing: up to 34 ipm (A4) - B/W duplex , Printing: up to 14 ppm (A5) - B/W portrait , Copying: up to 38 ppm (Letter A) - B/W normal , Copying: up to 38 ppm (A4) - B/W normal , Copying: up to 36 ppm (Letter A) - B/W duplex , Copying: up to 34 ppm (A4) - B/W duplex
- 1 x USB 2.0 , 1 x USB host , 1 x USB , 1 x Gigabit LAN - RJ-45
- Operating System Support
- Windows 11, Windows 10, MS Windows 7, Android, iOS, macOS 10.15, macOS 11, Chrome OS
- Software Included
- Drivers & Utilities, HP Smart App
- Voltage Required
- 510 Watt
- Power Consumption Standby
- 7.5 Watt
- Power Consumption Sleep
- 0.9 Watt
- Warm-Up Time
- 45 sec
- First Copy Out Time B/W
- 7.2 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 2900 pages
- RCM, TUV, GS, BSMI, CCC, KC, SIRIM, EAC, Ukraine, FCC, UL, CISPR 32:2015 Class B, EN 55032:2015 Class B, CISPR 35: 2016, EN 55035:2017 Class B, EN IEC 61000-3-2:2019, EN 61000-3-3:2013+A1:2019, EN 61000-4-12:2016, FCC CFR47 Part 15 B Class B, ICES-003 issue 7 Class B, ETSI EN 301 489-1 V2.2.3, ETSI EN 301 489-17 V3.2.4, IEEE 802.3az
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 42 cm
- 39 cm
- 32.3 cm
- 12.6 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 39.8 cm
- Shipping Height
- 49 cm
- Shipping Weight
- 15.5 kg
- Sound Emission
- 54 dBA (operating)
- 10 °C
- 32.5 °C
- 10 - 80% RH (non-condensing)
Ink (2)
HP HP - Black - original - LaserJet - toner cartridge | In Stock | £87.00 |
HP 149X - high capacity - black - original - LaserJet - toner cartridge | In Stock | £175.08 |
Other bundles (1)
HP 550 sheet paper tray for LaserJet Pro M402d, M402n, M402dn | In Stock | £97.28 |
