HP LaserJet Pro MFP 4102dw Multifunction Printer
Quicklinx: HF2QWS00 Mfr#: 2Z622F#B19
£309.16 ex VAT
£370.99 inc VAT
Get blazing fast printing speeds, high-volume scanning, and easy management tools with LaserJet Pro.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Maximum productivity
    Compact design with groundbreaking performance. High-speed, double-sided printing at up to 42 ppm and dual-sided scanning. HP Smart app enabled so you can easily print and scan from the cloud, including applications like Google Drive and Dropbox.
  • Seamless management
    Manage your printers with the powerful Web Jetadmin or connect your printers to the cloud with an HP account. Intuitive management tools help you set up your printers, onboard users, track toner levels, ensure security, and much more.
HP LaserJet Pro MFP 4102dw - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 38 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 4800 x 600 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, postcards, plain paper, light-weight paper, heavy-weight paper, bond paper, coloured paper, letterheaded paper, preprinted paper, prepunched paper, recycled paper, labels
Standard Media Capacity
350 sheets
Max Media Capacity
900 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Gigabit LAN, Wi-Fi(n), USB, USB host, Bluetooth LE, USB 2.0
AirPrint Enabled
Office Machine Features
HP Auto-On/Auto-Off Technology, Instant-on Technology, N-Up printing, ECO Mode, HP Instant Ink, JetIntelligence Cartridge Technology, Mopria certified, wireless direct printing, print from mobile devices, scan to e-mail, scan to PDF, scan to USB host, scan to folder, scan to Cloud, Private print
AC 230 V (50/60Hz)
42 cm x 39 cm x 32.3 cm
12.6 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Printer Fonts
TrueType x 84
Printing Technology
Laser - monochrome
80000 pages
750 - 4000 pages
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 38 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
ID Copy, resize, 2-up, collation copy, 2-sided copy orientation change, quality adjustment
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PDF, PostScript 3, PWG, URF
Image Enhancement Technology
HP FastRes 1200, HP ProRes 1200
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
53 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), 102 x 152 mm, Executive (184 x 267 mm), Oficio (216 x 343 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), JIS B5 (182 x 257 mm), 195 x 270 mm, 184 x 260 mm, 197 x 273 mm, JIS B6 (128 x 182 mm), Statement (139.7 x 215.9 mm), 100 x 150 mm
Supported Envelope Sizes
Japanese postcard (100 x 148 mm), Japanese Postcard Double (148 x 200 mm), US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm), International B5 (176 x 250 mm), International C5 (162 x 229 mm), International DL (110 x 220 mm)
350 sheets
Max Media Capacity
900 sheets
150 sheets
Input tray - 100 sheets weight: 60 g/m² - 200 g/m²; weight (lbs): 16 lbs - 53 lbs , Input tray - 250 sheets weight: 60 g/m² - 120 g/m²; weight (lbs): 16 lbs - 32 lbs , Output tray - 150 sheets , ADF - 50 sheets weight: 60 g/m² - 120 g/m²; weight (lbs): 16 lbs - 32 lbs
Speed Details
Scanning: up to 31 ppm (Letter A) - B/W normal , Scanning: up to 29 ppm (A4) - B/W normal , Scanning: up to 49 ipm (Letter A) - B/W normal , Scanning: up to 21 ppm (Letter A) - colour normal , Scanning: up to 36 ipm (Letter A) - colour normal , Scanning: up to 20 ppm (A4) - colour normal , Scanning: up to 34 ipm (A4) - colour normal , Printing: up to 42 ppm (Letter A) - B/W (ISO) , Printing: up to 40 ppm (A4) - B/W (ISO) , Printing: up to 63 ppm (A5) - B/W landscape , Printing: up to 36 ipm (Letter A) - B/W duplex , Printing: up to 34 ipm (A4) - B/W duplex , Printing: up to 14 ppm (A5) - B/W portrait , Copying: up to 38 ppm (Letter A) - B/W normal , Copying: up to 38 ppm (A4) - B/W normal , Copying: up to 36 ppm (Letter A) - B/W duplex , Copying: up to 34 ppm (A4) - B/W duplex
1 x USB 2.0 , 1 x USB host , 1 x USB , 1 x Gigabit LAN - RJ-45
Operating System Support
Windows 11, Windows 10, MS Windows 7, Android, iOS, macOS 10.15, macOS 11, Chrome OS
Software Included
Drivers & Utilities, HP Smart App
AC 230 V (50/60Hz)
510 watt
Power Consumption Standby
7.5 watt
Power Consumption Sleep
0.9 watt
Warm-Up Time
45 sec
First Copy Out Time B/W
7.2 sec
Consumables Included
1 x toner cartridge (black)
RCM, TUV, GS, BSMI, CCC, KC, SIRIM, EAC, Ukraine, FCC, UL, CISPR 32:2015 Class B, EN 55032:2015 Class B, CISPR 35: 2016, EN 55035:2017 Class B, EN IEC 61000-3-2:2019, EN 61000-3-3:2013+A1:2019, EN 61000-4-12:2016, FCC CFR47 Part 15 B Class B, ICES-003 issue 7 Class B, ETSI EN 301 489-1 V2.2.3, ETSI EN 301 489-17 V3.2.4
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
42 cm
39 cm
32.3 cm
12.6 kg
Shipping Width
49.7 cm
Shipping Depth
39.8 cm
Shipping Height
49 cm
Shipping Weight
15.5 kg
Sound Emission
54 dBA (operating)
10 °C
32.5 °C
10 - 80% RH (non-condensing)
Ink (2)
HF2Q HP HP - Black - original - LaserJet - toner cartridge In Stock £85.84
HF2Q HP 149X - high capacity - black - original - LaserJet - toner cartridge In Stock £172.59
Other bundles (1)
HF2Q HP 550 sheet paper tray for LaserJet Pro M402d, M402n, M402dn In Stock £100.51
Type: Printer / copier / scanner
Functionality: Printer
Functionality: Scanner
Functionality: Copier
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
