Get fast printing speeds, high-volume scanning, and easy management tools with LaserJet Pro.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
                Small workteam solutionSupport your small workteams with this laser printer, designed for up to 7 users.
                Fast print and duplex speedsPrint more efficiently. You can save time, paper, and costs with duplex speeds at 35 ppm.
                HP SmartGet productivity in the palm of your hand. Print, scan, and save time with Shortcuts from HP Smart.
                HP Web JetadminCentralize your print management. HP Web Jetadmin makes it easy with its suite of features.
                Simple setupSet up your printers quickly. Streamlined setup makes it easy to set up and get back to business.
- HP LaserJet Pro MFP 3102fdw - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, Spanish, French, Italian / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 350 - 2500 pages
- Max Copying Speed
- Up to 33 ppm
- Max Copying Resolution
- Up to 300 dpi
- Max Printing Speed
- Up to 33 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 203 x 196 dpi, 203 x 98 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.7"
- Original Size
- 76 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Postcards, envelopes, plain paper, glossy paper, film, labels, card stock
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), Bluetooth LE
- AirPrint Enabled
- Office Machine Features
- JetIntelligence Cartridge Technology, scan to PDF, scan to e-mail, print from USB flash drive, HP Instant Ink, print from mobile devices, HP Auto-Off Technology, Mopria certified
- Power
- AC 230 V
- 41.8 cm x 39.82 cm x 31.32 cm
- 10.5 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Printer Fonts
- TrueType x 84
- Fax Type
- Plain paper
- Laser - monochrome
- 50000 pages
- 350 - 2500 pages
- Display Diagonal Size
- 2.7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
Copying
- Max Copying Speed
- Up to 33 ppm
- Up to 300 dpi
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- Multiple Copy, margin erase, collation copy, quality adjustment
Printing
- Up to 33 ppm
- Printer Drivers / Emulations
- PCL 5c, PCL 6, PCLms, PDF, URF, PWG, PCLm
- Image Enhancement Technology
- HP REt, HP ProRes 1200
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 500 pages
- Fax Printing Speed
- Up to 20 ppm
- Fax Printing Resolution
- 600 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 200 station(s)
- Telephone / Fax Switch
- Delayed Transmission
- Junk fax barrier, fax forwarding, automatic redialing, auto reduction
Document & Media Handling
- Min Original Size
- 76 x 127 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), Oficio (216 x 343 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 195 x 270 mm, 197 x 273 mm, 90 x 130 mm, 100 x 150 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese postcard (100 x 148 mm), Japanese Postcard Double (148 x 200 mm), Japanese Chou No 4 (90 x 205 mm), International B5 (176 x 250 mm), International C5 (162 x 229 mm), International C6 (114 x 162 mm), International DL (110 x 220 mm)
- 250 sheets
- 250 sheets
- 150 sheets
- ADF - 50 sheets , Input tray - 250 sheets , Output tray - 150 sheets
- Speed Details
- Printing: up to 35 ppm (Letter A) - B/W (ISO) , Printing: up to 33 ppm (A4) - B/W (ISO) , Printing: up to 53 ppm (A5) - B/W landscape , Printing: up to 7 ppm (A5) - B/W portrait , Printing: up to 20 ipm (A4) - B/W duplex , Printing: up to 21 ipm (Letter A) - B/W duplex , Copying: up to 33 ppm (A4) - B/W normal , Copying: up to 35 ppm (Letter A) - B/W normal , Copying: up to 20 ppm (A4) - B/W duplex , Copying: up to 21 ppm (Letter A) - B/W duplex , Scanning: up to 19 ppm (A4) - B/W normal , Scanning: up to 8 ppm (A4) - colour normal , Scanning: up to 20 ppm (Letter A) - B/W normal , Scanning: up to 9 ppm (Letter A) - colour normal
- 1 x USB 2.0 , 1 x LAN
- IPv6 support, Wi-Fi Direct, Apple Bonjour, SNMP 3
- Operating System Support
- Windows 11, Windows 10, MS Windows 7 (32/64 bits), macOS 10.15, macOS 11, macOS 12 Monterey
- Voltage Required
- AC 230 V
- 436 Watt
- Power Consumption Standby
- 4.5 Watt
- Power Consumption Sleep
- 1.31 Watt
- Warm-Up Time
- 55 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752
- RCM, TUV, GS, BSMI, CCC, BIS, KC, SIRIM, Ukraine, EAC, FCC, UL, CISPR 32:2012, CISPR 32:2015, EN 55032:2012, EN 55032:2015+AC:2016 Class B, EN 61000-3-2:2014, EN 61000-3-3:2013, EN 55035:2017, FCC CFR47 Part 15 B, ICES-003 issue 6, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 62368-1:2014, IEC 62368-1: 2014, CAN/CSA-C22.2 No. 62368-1 Third Edition, UL 62368-1 Third Edition, IEC 60825-1:2014 Class 1 Third Edition, EN 62479:2010, IEC 62479:2010, EU Directive 2014/53/EU, EN 301 489-1 V2.2.3, EN 301 489-17 V3.2.0, EN 300 328 V2.1.1, EN 301 893 V2.1.1, EN 300 440-1 V2.1.1, FCC CFR47 Part 15 C, FCC CFR47 Part 15 E, RSS-247 Issue 1, RSS-102 Issue 5, IEC 62311:2007, EN 62311:2008, ES 203 021, PTC 200, Mercury-free
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 41.8 cm
- 39.82 cm
- 31.32 cm
- 10.5 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 37.9 cm
- Shipping Height
- 49 cm
- Shipping Weight
- 13.6 kg
- Sound Emission
- 14 dBA (idle) / 53 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80% RH
