HP LaserJet Pro MFP 3102fdw Mono Multifunction Printer
Quicklinx: J7BZWS00 Mfr#: 3G630F#B19
£267.55 ex VAT
£321.06 inc VAT
Get fast printing speeds, high-volume scanning, and easy management tools with LaserJet Pro.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Small workteam solution
    Support your small workteams with this laser printer, designed for up to 7 users.
  • Fast print and duplex speeds
    Print more efficiently. You can save time, paper, and costs with duplex speeds at 35 ppm.
  • HP Smart
    Get productivity in the palm of your hand. Print, scan, and save time with Shortcuts from HP Smart.
  • HP Web Jetadmin
    Centralize your print management. HP Web Jetadmin makes it easy with its suite of features.
  • Simple setup
    Set up your printers quickly. Streamlined setup makes it easy to set up and get back to business.
HP LaserJet Pro MFP 3102fdw - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, Spanish, French, Italian / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
350 - 2500 pages
Max Copying Speed
Up to 33 ppm
Max Copying Resolution
Up to 300 dpi
Max Printing Speed
Up to 33 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 203 x 196 dpi, 203 x 98 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
76 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Postcards, envelopes, plain paper, glossy paper, film, labels, card stock
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), Bluetooth LE
AirPrint Enabled
Office Machine Features
JetIntelligence Cartridge Technology, scan to PDF, scan to e-mail, print from USB flash drive, HP Instant Ink, print from mobile devices, HP Auto-Off Technology, Mopria certified
AC 230 V
41.8 cm x 39.82 cm x 31.32 cm
10.5 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Printer Fonts
TrueType x 84
Fax Type
Plain paper
Printing Technology
Laser - monochrome
50000 pages
350 - 2500 pages
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Up to 33 ppm
Up to 300 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
Multiple Copy, margin erase, collation copy, quality adjustment
Printing
Max Printing Speed
Up to 33 ppm
Printer Drivers / Emulations
PCL 5c, PCL 6, PCLms, PDF, URF, PWG, PCLm
Image Enhancement Technology
HP REt, HP ProRes 1200
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 500 pages
Fax Printing Speed
Up to 20 ppm
Fax Printing Resolution
600 dpi
PC Faxing
Fax Machine Features
Speed Dialing
200 station(s)
Telephone / Fax Switch
Delayed Transmission
Junk fax barrier, fax forwarding, automatic redialing, auto reduction
Document & Media Handling
Min Original Size
76 x 127 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), Oficio (216 x 343 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 195 x 270 mm, 197 x 273 mm, 90 x 130 mm, 100 x 150 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese postcard (100 x 148 mm), Japanese Postcard Double (148 x 200 mm), Japanese Chou No 4 (90 x 205 mm), International B5 (176 x 250 mm), International C5 (162 x 229 mm), International C6 (114 x 162 mm), International DL (110 x 220 mm)
250 sheets
Max Media Capacity
250 sheets
150 sheets
ADF - 50 sheets , Input tray - 250 sheets , Output tray - 150 sheets
Speed Details
Printing: up to 35 ppm (Letter A) - B/W (ISO) , Printing: up to 33 ppm (A4) - B/W (ISO) , Printing: up to 53 ppm (A5) - B/W landscape , Printing: up to 7 ppm (A5) - B/W portrait , Printing: up to 20 ipm (A4) - B/W duplex , Printing: up to 21 ipm (Letter A) - B/W duplex , Copying: up to 33 ppm (A4) - B/W normal , Copying: up to 35 ppm (Letter A) - B/W normal , Copying: up to 20 ppm (A4) - B/W duplex , Copying: up to 21 ppm (Letter A) - B/W duplex , Scanning: up to 19 ppm (A4) - B/W normal , Scanning: up to 8 ppm (A4) - colour normal , Scanning: up to 20 ppm (Letter A) - B/W normal , Scanning: up to 9 ppm (Letter A) - colour normal
1 x USB 2.0 , 1 x LAN
Security Protocols & Features
IPv6 support, Wi-Fi Direct, Apple Bonjour, SNMP 3
Operating System Support
Windows 11, Windows 10, MS Windows 7 (32/64 bits), macOS 10.15, macOS 11, macOS 12 Monterey
AC 230 V
436 Watt
Power Consumption Standby
4.5 Watt
Power Consumption Sleep
1.31 Watt
Warm-Up Time
55 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752
RCM, TUV, GS, BSMI, CCC, BIS, KC, SIRIM, Ukraine, EAC, FCC, UL, CISPR 32:2012, CISPR 32:2015, EN 55032:2012, EN 55032:2015+AC:2016 Class B, EN 61000-3-2:2014, EN 61000-3-3:2013, EN 55035:2017, FCC CFR47 Part 15 B, ICES-003 issue 6, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 62368-1:2014, IEC 62368-1: 2014, CAN/CSA-C22.2 No. 62368-1 Third Edition, UL 62368-1 Third Edition, IEC 60825-1:2014 Class 1 Third Edition, EN 62479:2010, IEC 62479:2010, EU Directive 2014/53/EU, EN 301 489-1 V2.2.3, EN 301 489-17 V3.2.0, EN 300 328 V2.1.1, EN 301 893 V2.1.1, EN 300 440-1 V2.1.1, FCC CFR47 Part 15 C, FCC CFR47 Part 15 E, RSS-247 Issue 1, RSS-102 Issue 5, IEC 62311:2007, EN 62311:2008, ES 203 021, PTC 200, Mercury-free
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
41.8 cm
39.82 cm
31.32 cm
10.5 kg
Shipping Width
49.7 cm
Shipping Depth
37.9 cm
Shipping Height
49 cm
Shipping Weight
13.6 kg
Sound Emission
14 dBA (idle) / 53 dBA (operating)
15 °C
32.5 °C
10 - 80% RH
Brand: HP
