Finish jobs faster, produce high-quality documents, and make scanning and sharing simple. Get set up and connected quickly. Send quick commands from an intuitive colour touchscreen. Easily conserve resources and recycle used cartridges.
Finish faster – with less standing around – using single-pass, dual-head scanning
Maintain peak performance with fast print speeds of up to 40 ppm . Rely on a robust recommended monthly page volume of 2000 to 6000 pages.Handle high-volume printing without worries, thanks to a 600-sheet paper input, expandable to 1100 sheets , and a 250-sheet output tray.Work faster, single-pass, dual-head scanning. Scan documents and send digital files to email, the cloud, network folders or a USB drive, in one easy step.Save paper with two-sided printing, and use the 50-sheet automatic document feeder to heighten productivity.
- HP LaserJet Pro MFP M521dn - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 75000 impressions
- Recommended Monthly Volume
- 2000 - 6000 pages
- Max Copying Speed
- Up to 40 ppm
- Max Copying Resolution
- Up to 300 x 300 dpi
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 300 x 300 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 3.5"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, card stock
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 1100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 350 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Document send function, save to USB flash drive, scan to e-mail, save to network folder, security lock slot
- Power
- AC 230 V (50/60Hz)
- 46.5 cm x 46.5 cm x 50.8 cm
- 22.3 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- 75000 impressions
- 2000 - 6000 pages
- Display Diagonal Size
- 3.5"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
Copying
- Max Copying Speed
- Up to 40 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 40 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c
- Image Enhancement Technology
- HP FastRes 1200 / HP ProRes 1200
- First Print Out Time B/W
- 8 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 250 pages
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Remote Fax Retrieval (Polling)
- Fax forwarding, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 52 g/m²
- Max Media Weight
- 199 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), B6 (125 x 176 mm), 76 x 127 mm, JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 600 sheets
- 1100 sheets
- 100 sheets
- 350 sheets
- ADF - 50 sheets - Legal (216 x 356 mm) , Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 52 g/m² - 199 g/m² , Input tray - 500 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 52 g/m² - 120 g/m² , Output tray - 250 sheets , Output tray - 100 sheets
- Speed Details
- Scanning: up to 19 ppm (A4) - B/W normal , Scanning: up to 14 ppm (A4) - colour normal , Printing: up to 40 ppm (A4) - B/W (ISO) , Copying: up to 40 ppm (A4) - B/W (ISO) , Printing: up to 21 ipm (A4) - B/W duplex , Printing: up to 42 ppm (Letter A) - B/W (ISO) , Copying: up to 42 ppm (Letter A) - B/W (ISO)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, Apple Bonjour, TLS, 802.1x
- Operating System Support
- MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, Sun Solaris 8, MS Windows 7, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, MS Windows Server 2008, Apple Mac OS X 10.6, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Linux Linpus Desktop 9.4, Linux Linpus Desktop 9.5, Ubuntu Linux 8.04.1 LTS, Ubuntu Linux 8.04.2 LTS, Apple Mac OS X 10.7, Debian Linux 5.0, MS Windows Server 2003 SP3 or later, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Oracle Solaris 9, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, Windows 8 64-bit
- Software Included
- Drivers & Utilities
- Voltage Required
- 760 Watt
- Power Consumption Standby
- 18.2 Watt
- Power Consumption Sleep
- 4.3 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages
- GS, EN55024, EN55022 Class A, CISPR 22, EMC, Laser Class 1, IEC 60950-1, EN 60950-1, FCC CFR47, EN 60825-1, GB 17625.1, LVD, GB 9254-2008, EN 61000-3-2:2006, EN 61000-3-3:2008
- Security Slot Type
- Kensington security slot
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 46.5 cm
- 46.5 cm
- 50.8 cm
- 22.3 kg
- Shipping Width
- 58.5 cm
- Shipping Depth
- 59.4 cm
- Shipping Height
- 73.3 cm
- Shipping Weight
- 29.57 kg
- Sound Emission
- 54 dBA (operating)
- 10 °C
- 32.5 °C
- 10 - 80%
Ink (4)
HP 55A Black Original LaserJet Toner Cartridge | In Stock | £129.28 |
HP 55X High Yield Black Original LaserJet Toner Cartridge | In Stock | £205.63 |
HP 55X 2-pack High Yield Black Original LaserJet Toner Cartridges | In Stock | £361.83 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £14.44 |
Other bundles (2)
HP Care Pack Installation Service Installation On-Site | In Stock | £145.19 |
HP 3yNbd LaserJet Pro M521MFP HW Support | In Stock | £284.00 |
