HP LaserJet Pro M521dn Mono Laser Multifunction Printer
Quicklinx: 8M9PWS00 Mfr#: A8P79A#B19
Finish jobs faster, produce high-quality documents, and make scanning and sharing simple. Get set up and connected quickly. Send quick commands from an intuitive colour touchscreen. Easily conserve resources and recycle used cartridges.
  • Finish faster – with less standing around – using single-pass, dual-head scanning
    Maintain peak performance with fast print speeds of up to 40 ppm . Rely on a robust recommended monthly page volume of 2000 to 6000 pages.Handle high-volume printing without worries, thanks to a 600-sheet paper input, expandable to 1100 sheets , and a 250-sheet output tray.Work faster, single-pass, dual-head scanning. Scan documents and send digital files to email, the cloud, network folders or a USB drive, in one easy step.Save paper with two-sided printing, and use the 50-sheet automatic document feeder to heighten productivity.
HP LaserJet Pro MFP M521dn - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
75000 impressions
Recommended Monthly Volume
2000 - 6000 pages
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 300 x 300 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Display
3.5"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, card stock
Standard Media Capacity
600 sheets
Max Media Capacity
1100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
350 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Document send function, save to USB flash drive, scan to e-mail, save to network folder, security lock slot
AC 230 V (50/60Hz)
46.5 cm x 46.5 cm x 50.8 cm
22.3 kg
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
75000 impressions
2000 - 6000 pages
Display Diagonal Size
3.5"
Display Features
Touch screen
AirPrint Enabled
Copying
Max Copying Speed
Up to 40 ppm
Up to 300 x 300 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c
Image Enhancement Technology
HP FastRes 1200 / HP ProRes 1200
Automatic Duplexing
First Print Out Time B/W
8 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 250 pages
Fax Machine Features
Speed Dialing
100 station(s)
Remote Fax Retrieval (Polling)
Fax forwarding, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
52 g/m²
Max Media Weight
199 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), B6 (125 x 176 mm), 76 x 127 mm, JIS B6 (128 x 182 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
600 sheets
Max Media Capacity
1100 sheets
100 sheets
350 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 52 g/m² - 199 g/m² , Input tray - 500 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 52 g/m² - 120 g/m² , Output tray - 250 sheets , Output tray - 100 sheets
Speed Details
Scanning: up to 19 ppm (A4) - B/W normal , Scanning: up to 14 ppm (A4) - colour normal , Printing: up to 40 ppm (A4) - B/W (ISO) , Copying: up to 40 ppm (A4) - B/W (ISO) , Printing: up to 21 ipm (A4) - B/W duplex , Printing: up to 42 ppm (Letter A) - B/W (ISO) , Copying: up to 42 ppm (Letter A) - B/W (ISO)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, Apple Bonjour, TLS, 802.1x
Operating System Support
MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, Sun Solaris 8, MS Windows 7, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, MS Windows Server 2008, Apple Mac OS X 10.6, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Linux Linpus Desktop 9.4, Linux Linpus Desktop 9.5, Ubuntu Linux 8.04.1 LTS, Ubuntu Linux 8.04.2 LTS, Apple Mac OS X 10.7, Debian Linux 5.0, MS Windows Server 2003 SP3 or later, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Oracle Solaris 9, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, Windows 8 64-bit
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
760 Watt
Power Consumption Standby
18.2 Watt
Power Consumption Sleep
4.3 Watt
Phone cable
Consumables Included
1 x toner cartridge (black) - up to 6000 pages
GS, EN55024, EN55022 Class A, CISPR 22, EMC, Laser Class 1, IEC 60950-1, EN 60950-1, FCC CFR47, EN 60825-1, GB 17625.1, LVD, GB 9254-2008, EN 61000-3-2:2006, EN 61000-3-3:2008
Security Slot Type
Kensington security slot
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
46.5 cm
46.5 cm
50.8 cm
22.3 kg
Shipping Width
58.5 cm
Shipping Depth
59.4 cm
Shipping Height
73.3 cm
Shipping Weight
29.57 kg
Sound Emission
54 dBA (operating)
10 °C
32.5 °C
10 - 80%
Ink (4)
8M9P HP 55A Black Original LaserJet Toner Cartridge In Stock £133.44
8M9P HP 55X High Yield Black Original LaserJet Toner Cartridge In Stock £207.50
8M9P HP 55X 2-pack High Yield Black Original LaserJet Toner Cartridges In Stock £373.49
8M9P HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £15.34
Other bundles (2)
8M9P HP Care Pack Installation Service Installation On-Site In Stock £145.19
8M9P HP 3yNbd LaserJet Pro M521MFP HW Support In Stock £285.43
