HP LaserJet Pro M377dw Colour MFP Printer
Quicklinx: DC7NWS00 Mfr#: M5H23A#B19
Print, copy and scan with this easy-to-use, smallest-in-class colour MFP that offers two-sided printing and wireless connectivity, and helps you finish tasks fast. Original HP Toner cartridges with JetIntelligence produce more pages.
HP Color LaserJet Pro MFP M377dw - multifunction printer - colour
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 24 ppm (mono) / up to 24 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 38400 x 600 dpi (mono) / up to 38400 x 600 dpi (colour)
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
48.8 x 48.8 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, photo paper, bond paper, glossy paper, punched paper, preprinted paper, postcards
Standard Media Capacity
300 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, save to network folder, scan to Cloud, Instant-on Technology, Instant-on Copy
AC 230 V (50Hz)
41.6 cm x 47.2 cm x 40 cm
23.2 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Printing Technology
Laser - colour
50000 pages
750 - 4000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Fit to page, ID Card Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, PCLm, URF
Image Enhancement Technology
HP ImageREt 3600, Pantone Calibrated
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
30-bit
Document & Media Handling
Min Original Size
48.8 x 48.8 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, Folio (216 x 330 mm), 100 x 148 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 76 x 127 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
300 sheets
Max Media Capacity
850 sheets
50 sheets
150 sheets
ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Input tray - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m²
Speed Details
Printing: up to 24 ppm (A4) - B/W normal , Printing: up to 24 ppm (A4) - colour normal , Printing: up to 25 ppm (Letter A) - B/W , Printing: up to 25 ppm (Letter A) - colour , Printing: up to 19 ipm (A4) - B/W duplex , Printing: up to 19 ipm (A4) - colour duplex , Printing: up to 20 ipm (Letter A) - B/W duplex , Printing: up to 20 ipm (Letter A) - colour duplex , Copying: up to 24 ppm (A4) - B/W normal , Copying: up to 24 ppm (A4) - colour normal , Copying: up to 25 ppm (Letter A) - B/W , Copying: up to 25 ppm (Letter A) - colour , Scanning: up to 26 ppm (A4) - B/W normal , Scanning: up to 21 ppm (A4) - colour normal , Scanning: up to 26 ppm (Letter A) - B/W normal , Scanning: up to 21 ppm (Letter A) - colour normal
2 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Operating System Support
Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 SP2 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Novell NetWare 6.5 SP8, Novell Open Enterprise Server 11 SP1, Novell Open Enterprise Server 2
Software Included
Drivers & Utilities
AC 230 V (50Hz)
560 Watt
Power Consumption Standby
19 Watt
Power Consumption Sleep
2.4 Watt
USB cable
Consumables Included
1 x toner cartridge (black) - up to 2300 pages , 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages
FCC Class B certified, cUL, GS, CB, EMC, Laser Class 1, FCC CFR47 Part 15, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, ICES-003 issue 5 Class B, EN 62479:2010, LVD 2006/95/EC, 21 CFR 1040.10, 21 CFR 1040.11, CoC, EN 55024:2010, CISPR 22:2008, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60825-1:2007, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 55022:2010 Class B
ENERGY STAR Certified
Blue Angel Compliant
41.6 cm
47.2 cm
40 cm
23.2 kg
Shipping Weight
26.8 kg
Sound Emission
30 dBA (idle) / 51 dBA (operating)
15 °C
30 °C
10 - 90% (non-condensing)
