HP LaserJet Pro M304a Mono Laser Printer
Quicklinx: FV45WS00 Mfr#: W1A66A#B19
Winning in business means working smarter. The HP LaserJet Pro M304a printer is designed to let you focus your time where it's most effective – helping to grow your business and staying ahead of the competition.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
  • Built to keep you – and your business – moving forward
    Grab pages and go – without waiting. This device wakes up and prints fast.Work with less wait. Step up your productivity with print speeds up to 35 (A4) pages per minute (ppm).Keep your office secure with a non-networked printer.
  • Simply designed to uncomplicate your day
    Set up this printer fast and easily manage device settings to help increase overall printing efficiency.Make the most of your office space with a printer that conveniently fits into your workstyle.The 2-line LCD display is simple to read and operate.Work without delays or messes, with cartridges featuring auto seal removal.
  • Sustainability is smart business
    Avoid frustrating reprints, wasted supplies, and service calls using Original HP toner cartridges.Saves up to 18% energy over prior products.
HP LaserJet Pro M304a - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
8.22 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
4800 x 600 dpi
Image Enhancement Technology
HP ProRes 1200 / HP FastRes 1200
USB 2.0
1.2 GHz
RAM Installed (Max)
256 MB (256 MB)
Flash Memory Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF, URF, PWG
Media Type
Envelopes, labels, plain paper, photo paper
Total Media Capacity
350 sheets
Media Handling
250-sheet input tray, 100-sheet input tray
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Printer Features
Auto Power On, Auto Power Off
Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10 (32/64 bits), Apple macOS 10.12, Apple macOS 10.13, Apple macOS 10.14
1-year warranty
38.1 cm x 35.7 cm x 21.6 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB 2.0
4800 x 600 dpi
Language Simulation
Fonts Included
84 x TrueType
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Flash Memory
Flash Memory
256 MB (installed) / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, JIS B6 (128 x 182 mm)
Media Weight
60 g/m² - 175 g/m²
Media Weight (lbs)
16 lbs - 46.6 lbs
350 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 175 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 175 g/m²
Max Media Capacity
900 sheets
Output Trays Capacity
150 sheets
Duty Cycle
80000 pages
750 - 4000 pages
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 1500 pages
ICES-003, EMC, EN 62479:2010, EN 61000-3-3:2013, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, FCC CFR47 Part 15 B Class B, EN 55024:2010+A1:2015, CISPR 32:2012, EN 55032:2015 Class B, EN 60825-1:2014, EN 55032:2012 Class B, IEC 60825-1:2014, CISPR 32:2015, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Power supply - internal
Frequency Required
50/60 Hz
495 watt
Power Consumption Stand by
5.5 watt
Power Consumption Sleep
0.5 watt
Limited warranty - 1 year
15 °C
32.5 °C
10 - 80%
Sound Emission (Idle)
16 dBA
Sound Emission (Operating)
54 dBA
38.1 cm
35.7 cm
21.6 cm
8.22 kg
Ink (3)
FV45 HP 59A Black Original LaserJet Toner Cartridge In Stock £88.22
FV45 HP 59X High Yield Black Original LaserJet Toner Cartridge In Stock £184.77
FV45 HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.62
Other bundles (1)
FV45 HP 550 sheet paper tray for LaserJet Pro M402d, M402n, M402dn In Stock £100.51
