HP LaserJet Pro M28w Mono Multifunction Printer
Quicklinx: F8VMWS00 Mfr#: W2G55A#B19
Get productive MFP performance that fits your space and your budget. Print, scan, and copy produce professional-quality results. Easily print and scan from your smartphone.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Tackle the essentials – print, scan, copy
    Get versatile performance and print, scan, and copy.
  • Fast printing
    Get print speeds up to 18/19 ppm.
  • Small size. Big performance
    A LaserJet MFP so small it can fit almost anywhere.
  • Simply scan to email
    Multi-destination digital sending.
  • Easy ID copying
    Easily copy both sides of identification cards onto one side of paper.
  • Uncompromising laser quality
    This surprisingly small laser delivers exceptional quality, page after page.
HP LaserJet Pro MFP M28w - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 pages
Recommended Monthly Volume
100 - 1000 pages
Max Copying Speed
Up to 18 ppm
Max Copying Resolution
Up to 600 x 400 dpi
Max Printing Speed
Up to 18 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Scanning
1200 x 1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
105 x 148 mm (min) - A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, postcards
Standard Media Capacity
150 sheets
Max Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
HP Auto-On/Auto-Off Technology, scan to image
AC 230 V (50/60Hz)
36 cm x 26.4 cm x 19.7 cm
5.4 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Laser - monochrome
8000 pages
100 - 1000 pages
Display Features
LCD display
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Standard Memory
32 MB
Max Supported Memory
32 MB
Copying
Max Copying Speed
Up to 18 ppm
Up to 600 x 400 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
ID Card Copy
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 18 ppm
Printer Drivers / Emulations
PDF, TIFF, PCLms, URF, PWG, JPEG
Image Enhancement Technology
HP FastRes 600
First Print Out Time B/W
8.2 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
105 x 148 mm
Max Media Size
A4
Min Media Weight
65 g/m²
Max Media Weight
120 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), C5 (162 x 229 mm), DL (210 x 99 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm)
150 sheets
Max Media Capacity
150 sheets
100 sheets
Input tray - 150 sheets - A4 (210 x 297 mm) weight: 65 g/m² - 120 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 18 ppm (A4) - B/W (ISO) , Copying: up to 18 ppm (A4) - B/W normal , Printing: up to 7 ppm (A5) - B/W portrait , Printing: up to 19 ppm - B/W
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
Apple Bonjour, Wi-Fi Direct
Operating System Support
MS Windows Server 2003 SP1 or later, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2003 x64 Edition SP1 or later, Apple Mac OS X 10.9, MS Windows Server 2008 Enterprise, MS Windows Server 2008 Standard, MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
365 Watt
Power Consumption Standby
2.9 Watt
Power Consumption Sleep
0.6 Watt
First Copy Out Time B/W
10.2 sec
Consumables Included
1 x toner cartridge (black) - up to 500 pages
EN 62479:2010, IEC 62471:2006, EN 62471:2008, EN 61000-3-3:2013, EN 55024:2010, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 55032:2012, IEC/EN60950-1:2006 +A11:2009 +A1:2010 +A12:2011 +A2:2013, IEC/EN 60825-1:2014 Class 1, CISPR 32:2012, EN 60825-1:2014
ENERGY STAR Certified
Limited warranty - 1 year
36 cm
26.4 cm
19.7 cm
5.4 kg
Shipping Width
39.8 cm
Shipping Depth
24.8 cm
Shipping Height
30.6 cm
Shipping Weight
6.9 kg
Sound Emission
52 dBA (operating)
15 °C
32.5 °C
10 - 80%
Ink (1)
F8VM HP 44A Black Original LaserJet Cartridge In Stock £42.06
Other bundles (2)
F8VM HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £33.36
F8VM HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment for LaserJet 1018s In Stock £27.81
