Brand
HP LaserJet Pro M15w Printer
Quicklinx: G4L9WS00 Mfr#: W2G51A#B19
Get fast printing that fits your space and your budget. Produce professional-quality results, and print and scan from your smartphone.
This printer uses dynamic security, which may be updated periodically by firmware updates. The printer is intended to be used solely with cartridges using an original HP chip. Cartridges using a non-HP chip may not function or may cease to function. More at:
  • Fast printing that fits anywhere
    Maximise your uptime with print speeds up to 18/19ppm.A LaserJet so small it can fit almost anywhere.Smartly and elegantly designed, so it's simple and intuitive to use.
  • Uncompromising quality
    This surprisingly small laser delivers exceptional quality, page after page.Help save energy with HP Auto-On/Auto-Off Technology.Speed through print jobs, using a pre-installed Original HP Toner cartridge.
  • Easy mobile printing and scanning with HP Smart App
    Print from the cloud, scan from your smartphone, and easily order toner, with the HP Smart app.Easily print from a variety of smartphones and tablets.Easily share resources – access and print with wireless networking.Connect your smartphone directly to your printer – and easily print without accessing a network.
HP LaserJet Pro M15w - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
3.8 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Min Media Size (Custom)
105 mm x 148 mm
Max Media Size (Custom)
216 mm x 297 mm
Print Speed
Up to 18 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 19 ppm - B/W , Up to 7 ppm - black portrait - A5 (148 x 210 mm)
Max Resolution (B&W)
600 x 600 dpi
USB 2.0, Wi-Fi(n)
AirPrint Enabled
500 MHz
RAM Installed (Max)
16 MB (16 MB)
Language Simulation
PCLm, URF, PWG
Media Type
Envelopes, labels, plain paper, postcards
Total Media Capacity
150 sheets
Media Handling
150-sheet input tray
Monthly Duty Cycle (max)
8000 pages
Recommended Monthly Volume
100 - 1000 pages
Printer Features
Print from mobile device, Auto Power Off
Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
1-year warranty
34.6 cm x 18.9 cm x 15.9 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Preview screen
Wireless
USB 2.0, Wi-Fi(n)
AirPrint Enabled
600 x 600 dpi
First Print Out Time B/W
8.4 sec
Language Simulation
PCLm, URF, PWG
Printer Features
Media Handling
500 MHz
RAM
RAM Installed (Max)
16 MB / 16 MB (max)
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
105 mm x 148 mm
216 mm x 297 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm), 147 x 211 mm, DL (210 x 99 mm)
Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm)
Media Weight
65 g/m² - 120 g/m²
150 sheets
Media Feeders
1 x automatic - 150 sheets - A4 (210 x 297 mm) weight: 65 g/m² - 120 g/m²
Max Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Duty Cycle
8000 pages
100 - 1000 pages
Remote Management Protocol
SNMP 1
Security Protocols & Features
Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 1000 pages
SNMP support
EN 62479:2010, EN 61000-3-3:2013, EN 55024:2010, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 55032:2012, IEC/EN60950-1:2006 +A11:2009 +A1:2010 +A12:2011 +A2:2013, IEC/EN 60825-1:2014 Class 1, CISPR 32:2012
Power supply - internal
Frequency Required
50 Hz
210 Watt
Power Consumption Stand by
2.2 Watt
Power Consumption Sleep
0.4 Watt
Software Included
Drivers & Utilities, HP Utility Center, HP Software Installer, HP Software Uninstaller, HP Device Experience (DXP), HP Web Services Assist, HP Printer Assistant
System Requirements Details
Windows 7/8/8.1/10 - HD 2 GB , macOS Sierra 10.12 - HD 1.5 GB
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
15 °C
32.5 °C
10 - 80%
Sound Emission (Operating)
51 dBA
34.6 cm
18.9 cm
15.9 cm
3.8 kg
Width (Shipping)
37.8 cm
Depth (Shipping)
19.8 cm
Ink (1)
G4L9 HP 44A Black Original LaserJet Cartridge In Stock £40.21
Other bundles (2)
G4L9 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £32.80
G4L9 HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment for LaserJet 1018s In Stock £27.33
