HP LaserJet Pro M130fn Multi-Function Printer
Quicklinx: CB9MWS00 Mfr#: G3Q59A#B19
Functionality: Copier, Fax, Printer, Scanner
Technology: Laser
£147.87 ex VAT
£177.44 inc VAT
Keep things simple with HP's smallest LaserJet MFP – powered by JetIntelligence Toner cartridges. Print professional documents from a range of mobile devices, plus scan, copy, fax, and help save energy with an MFP designed for efficiency.
HP LaserJet Pro MFP M130fn - multifunction printer
  • Device Type: Fax / copier / printer / scanner
  • Fax Type: Plain paper
  • Max Copying Resolution: Up to 600 x 600 dpi
  • Max Printing Resolution: Up to 600 x 1200 dpi
  • Original Type: Sheets
  • PC Connection Availability: Yes
  • PC Connection: USB 2.0, Wi-Fi(n)
  • AirPrint Enabled: Yes
  • Power: ( 50/60Hz )
  • Environmental Standards ENERGY STAR Qualified
HP LaserJet Pro MFP M130fn - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
10000 pages
Recommended Monthly Volume
150 - 1500 pages
Max Copying Speed
Up to 23 ppm
Up to 600 x 400 dpi
Max Printing Speed
Up to 23 ppm
Up to 1200 dpi
Fax Resolutions
203 x 98 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Original Size
148.6 x 210.1 mm (min) - 215.9 x 297.2 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Media Type
Envelopes, plain paper, labels, photo paper, vellum paper, card stock, postcards
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
USB 2.0, LAN
AirPrint Enabled
Office Machine Features
Instant-on Technology, Mobile Printing, JetIntelligence Cartridge Technology
AC 230 V (50/60Hz)
41.5 cm x 28.8 cm x 27.9 cm
7.6 kg
Fax Type
Plain paper
Printing Technology
Laser - monochrome
10000 pages
150 - 1500 pages
Display
2 lines
USB 2.0, LAN
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Up to 23 ppm
Up to 600 x 400 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 1200 dpi
Max Printing Speed
Up to 23 ppm
Printer Drivers / Emulations
PCLms, URF, PWG
Image Enhancement Technology
HP FastRes 1200
First Print Out Time B/W
7.3 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
Total Memory Capacity
Up to 1000 pages
PC Faxing
Fax Machine Features
Speed Dialing
120 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), poll receive
Document & Media Handling
Min Original Size
148.6 x 210.1 mm
Max Original Size
215.9 x 297.2 mm
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), 76.2 x 127 mm, 215.9 x 330.2 mm
150 sheets
100 sheets
Input tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) , Output tray - 100 sheets
Speed Details
Printing: up to 23 ppm (Letter A) - B/W , Copying: up to 23 ppm (Letter A) - B/W , Scanning: up to 12 ppm
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 2 x modem - RJ-11
Operating System Support
Linux, Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
255 Watt
Power Consumption Standby
4.2 Watt
Power Consumption Sleep
1 Watt
Phone cable
Consumables Included
1 x Cartridge (black) - up to 700 pages , 1 x drum - up to 12000 pages
ENERGY STAR Certified
41.5 cm
28.8 cm
27.9 cm
7.6 kg
Shipping Width
49 cm
Shipping Depth
35 cm
Shipping Height
32.7 cm
Shipping Weight
10.2 kg
Sound Emission
51 dBA (operating)
15 °C
32.5 °C
10 - 80%
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Technology: Laser
Brand: HP
Price Range Ex VAT: 100 - 150
