Keep things simple with HP's smallest LaserJet MFP – powered by JetIntelligence Toner cartridges. Print professional documents from a range of mobile devices, plus scan, copy, fax, and help save energy with an MFP designed for efficiency.
HP LaserJet Pro MFP M130fn - multifunction printer
- Device Type: Fax / copier / printer / scanner
- Fax Type: Plain paper
- Max Copying Resolution: Up to 600 x 600 dpi
- Max Printing Resolution: Up to 600 x 1200 dpi
- Original Type: Sheets
- PC Connection Availability: Yes
- PC Connection: USB 2.0, Wi-Fi(n)
- AirPrint Enabled: Yes
- Power: ( 50/60Hz )
- Environmental Standards ENERGY STAR Qualified
- HP LaserJet Pro MFP M130fn - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 10000 pages
- Recommended Monthly Volume
- 150 - 1500 pages
- Max Copying Speed
- Up to 23 ppm
- Up to 600 x 400 dpi
- Max Printing Speed
- Up to 23 ppm
- Up to 1200 dpi
- Fax Resolutions
- 203 x 98 dpi, 300 x 300 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- 148.6 x 210.1 mm (min) - 215.9 x 297.2 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Media Type
- Envelopes, plain paper, labels, photo paper, vellum paper, card stock, postcards
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Office Machine Features
- Instant-on Technology, Mobile Printing, JetIntelligence Cartridge Technology
- Power
- AC 230 V (50/60Hz)
- 41.5 cm x 28.8 cm x 27.9 cm
- 7.6 kg
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- 10000 pages
- 150 - 1500 pages
- Display
- 2 lines
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Up to 23 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 1200 dpi
- Up to 23 ppm
- Printer Drivers / Emulations
- PCLms, URF, PWG
- Image Enhancement Technology
- HP FastRes 1200
- First Print Out Time B/W
- 7.3 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Fax Resolutions
- Total Memory Capacity
- Up to 1000 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 120 station(s)
- Delayed Transmission
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), poll receive
Document & Media Handling
- Min Original Size
- 148.6 x 210.1 mm
- Max Original Size
- 215.9 x 297.2 mm
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), 76.2 x 127 mm, 215.9 x 330.2 mm
- 150 sheets
- 100 sheets
- Input tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) , Output tray - 100 sheets
- Speed Details
- Printing: up to 23 ppm (Letter A) - B/W , Copying: up to 23 ppm (Letter A) - B/W , Scanning: up to 12 ppm
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 2 x modem - RJ-11
- Operating System Support
- Linux, Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
- Software Included
- Drivers & Utilities
- Voltage Required
- 255 Watt
- Power Consumption Standby
- 4.2 Watt
- Power Consumption Sleep
- 1 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages , 1 x drum - up to 12000 pages
- ENERGY STAR Certified
- 41.5 cm
- 28.8 cm
- 27.9 cm
- 7.6 kg
- Shipping Width
- 49 cm
- Shipping Depth
- 35 cm
- Shipping Height
- 32.7 cm
- Shipping Weight
- 10.2 kg
- Sound Emission
- 51 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
