This affordable HP LaserJet Pro MFP is easy to install and delivers crisp, clear documents. Print, copy and scan with one, compact device that fits neatly into small office spaces.
Extend your printing reach
Keep up with the pace of business: print and copy at high speeds of 20 ppm.Get a first page out in as fast as 9.5 sec. -
Print on your terms
Print from virtually anywhere – using your smartphone, tablet and PC – with Apple AirPrint .Easily print from mobile devices – without a network – using wireless direct printing.Connect your MFP directly to a PC or Netbook via the included Hi-Speed USB 2.0 port. -
Handle the essentials
Speed through document tasks and set the pace for success with an MFP that prints, copies and scans fast.Easily copy both sides of a two-sided ID or other small document onto the front of a single-page.Control made easy – just start printing right away with the easy-to-use, intuitive control panel.
- HP LaserJet Pro MFP M125nw - multifunction printer - B/W
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 8000 pages
- Recommended Monthly Volume
- 250 - 2000 pages
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 400 x 600 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Up to 600 x 600 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- 216 x 279 mm (max)
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Power
- AC 230 V
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- 1-year warranty
- Laser - monochrome
- 8000 pages
- 250 - 2000 pages
- Display
- 2 lines
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 20 ppm
- Printer Drivers / Emulations
- PCL
- Image Enhancement Technology
- HP FastRes 1200
- First Print Out Time B/W
- 9.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 279 mm
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm), 76 x 127 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 100 sheets
- Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- WEP, WPA, WPA2
- Software Included
- HP Toolbox
- Voltage Required
- AC 230 V
- Included Accessories
- USB cable
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 1 year
- Shipping Width
- 49.7 cm
- Shipping Depth
- 35 cm
- Shipping Height
- 33.2 cm
- Shipping Weight
- 10.3 kg
