Tackle everyday office tasks with an affordable, full-featured MFP. Plug and print with HP Smart Install. Easily print, copy, scan and fax from one compact machine. Share resources with Ethernet networking or work anywhere with wireless.
Be more efficient with this affordable, full-featured MFP
Share on a network and work from anywhere in the office, using built-in Ethernet and wireless connectivity.Create professional-quality documents with bold, crisp text and sharp images, using HP Original print cartridges.Send and receive faxes from your PC, using the 33.6 kbps fax.Print documents at up to 18 ppm A4. With Instant-on Technology, pages start and finish printing quickly: get a first page out in as fast as 8.5 seconds. -
Get up and running quickly and easily
Plug and print in as fast as five minutes: HP Smart Install makes it easy to start printing from a PC or Netbook – no CD required.Set up and start printing fast with an easy-to-use, intuitive control panel. Easily make a one-sided copy of a two-sided identification card with ID Copy.Connect the MFP directly to a PC or Netbook via the included Hi-speed USB 2.0 port.Ensure reliable printing with an HP all-in-one print cartridge. Easily replace it with HP SureSupply. -
Reduce your environmental impact and protect your bottom line
Get up to 50% energy savings using Instant-on Technology and save up to four times the energy with Instant-on Copy. Save even more with HP Auto-On/Auto-Off Technology which senses your printing activity, turning on and off automatically.Reduce waste: a pre-installed cartridge decreases packaging. Recycle easily with HP Planet Partners.Get more value and better results with the services, solutions, software and support of HP Total Care.Save energy with an ENERGY STAR qualified MFP.
- HP LaserJet Pro M1217nfw MFP - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 8000 impressions
- Recommended Monthly Volume
- 250 - 2000 pages
- Max Copying Speed
- Up to 18 ppm
- Max Copying Resolution
- Up to 600 x 400 dpi
- Max Printing Speed
- Up to 18 ppm
- Max Printing Resolution
- Up to 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 300 x 300 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- Office Machine Features
- Scan to e-mail, scan to application
- Power
- AC 230 V (50/60Hz)
- 43.5 cm x 26.5 cm x 30.6 cm
- 8.3 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - monochrome
- 8000 impressions
- 250 - 2000 pages
- Display
- 2 lines x 16 characters
- Interface
- Localisation
- Standard Memory
- 64 MB 64 MB
- Max Supported Memory
- 64 MB 64 MB
Copying
- Max Copying Speed
- Up to 18 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 1200 dpi
- Up to 18 ppm
- Image Enhancement Technology
- HP FastRes 1200
- First Print Out Time B/W
- 8.5 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 19200 dpi
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 500 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Delayed Transmission
- Remote Fax Retrieval (Polling)
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, answering machine interface, junk fax barrier, auto reduction
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), C5 (162 x 229 mm), C6 (114 x 162 mm), 76 x 127 mm
- 150 sheets
- 100 sheets
- ADF - 35 sheets , Input tray - 150 sheets , Output tray - 100 sheets
- Speed Details
- Printing: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - B/W
- 1 x USB 2.0 , 1 x LAN
- Operating System Support
- MS Windows XP, Linux, MS Windows Server 2003, Apple Mac OS X 10.4, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6
- Software Included
- Readiris Pro
- Voltage Required
- 370 Watt
- Power Consumption Standby
- 4.8 Watt
- Power Consumption Sleep
- 2 Watt
- Included Accessories
- USB cable, phone cable
- Consumables Included
- 1 x toner cartridge (black)
- EN 61000-3-2, EN55022, IEC 61000-4-11, EN 61000-3-3, EN55024, CISPR 22, RSS-210, EN 61000-4-4, EN 61000-4-3, EN 61000-4-6, FCC Part 68, EN 61000-4-5, UL 60950-1, IEC 60950-1, EN 60950-1, EN 300.489.1, IEC 60825-1, FCC CFR47 Part 15 C, TBR21, EN 60825-1, EN 300 328
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 43.5 cm
- 26.5 cm
- 30.6 cm
- 8.3 kg
- Shipping Width
- 59.7 cm
- Shipping Depth
- 39.7 cm
- Shipping Height
- 35.1 cm
- Shipping Weight
- 10.8 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 32.5 °C
- 10 - 80%
