HP LaserJet Pro M1132 Mono Laser Multifunction Printer
HP LaserJet Pro M1132 Multifunction Printer
Quicklinx: 72PSWS00 Mfr#: CE847A#B19
Tackle everyday office tasks, using this compact multifunction printer. Print, copy and scan from one affordable, easy-to-use MFP. Energy-saving features help reduce your environmental impact and save you money.
  • Get more done with this affordable HP LaserJet Pro MFP
    Increase efficiency and make the most of your resources: print, copy and scan with one compact, space-saving machine.Print high-quality documents with bold, crisp text and sharp images, using Original HP print cartridges.Print at speeds up to 18 ppm A4 and start and finish printing quickly with Instant-on Technology which delivers a first page out (from Auto-Off mode) in as fast as 8.5 seconds.
  • Get up and running quickly and easily
    Set up and start printing right away with this MFP's easy-to-use, intuitive control panel.Easily connect the MFP directly to a PC via the included Hi-speed USB 2.0 port.Ensure reliable printing, page after page, cartridge after cartridge, with Original HP supplies designed specifically for your printer. HP SureSupply helps you easily find and purchase a replacement cartridge.
  • Reduce your environmental impact and protect your bottom line
    Get up to 50 percent energy savings with Instant-on Technology and save up to four times the energy with Instant-on Copy.Save even more energy with HP Auto-On/Auto-Off Technology which senses your printing activity and turns the MFP on and off automatically.Reduce your impact on the environment and reduce waste with pre-installed cartridges which decrease packaging.Return cartridges through HP Planet Partners for easy, free recycling.
HP LaserJet Pro M1132 MFP - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 impressions
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 18 ppm
Max Copying Resolution
Up to 600 x 400 dpi
Max Printing Speed
Up to 18 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Scanning
1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Media Size
A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
150 sheets
Max Media Capacity
100 sheets
Connection Availability
USB 2.0
41.5 cm x 26.5 cm x 25 cm
7 kg
Enclosure Colour
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Laser - monochrome
8000 impressions
250 - 2000 pages
USB 2.0
Enclosure Colour
Standard Memory
8 MB 8 MB
Max Supported Memory
8 MB 8 MB
Copying
Max Copying Speed
Up to 18 ppm
Up to 600 x 400 dpi
Max Document Enlargement
400%
Max Document Reduction
30%
Maximum Copies
99
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 18 ppm
Image Enhancement Technology
HP FastRes 1200
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
1200 dpi
Colour Depth
24-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
Max Media Size
A4
Supported Media Type
150 sheets
Max Media Capacity
100 sheets
Input tray - 150 sheets - Legal (216 x 356 mm)
1 x USB 2.0
Operating System Support
MS Windows XP, Linux, Apple Mac OS X 10.4, Apple Mac OS X 10.5, MS Windows 7, Apple Mac OS X 10.6.x, MS Windows Vista
375 watt
Power Consumption Standby
3.2 watt
ENERGY STAR Certified
Limited warranty - 1 year
41.5 cm
26.5 cm
25 cm
7 kg
Shipping Width
49.7 cm
Shipping Depth
35.1 cm
Shipping Height
33 cm
Shipping Weight
9.4 kg
10 °C
32.5 °C
10 - 80%
72PS HP 85A 2-pack Black Original LaserJet Toner Cartridges In Stock £122.46
