Keep things simple with an affordable HP LaserJet Pro powered by JetIntelligence Toner cartridges. Produce consistent, professional documents from a compact laser printer designed for efficiency.
Designed for efficiency
Help save energy. This efficient HP LaserJet Pro printer delivers documents quickly while helping to keep energy costs low, so you save resources.
Mobile printing made simple with the HP LaserJet Pro M102w
No network, no problem. Easily print from your laptop or PC, using a USB cable.
HP quality – print after print
Count on consistent results – Original HP Toner cartridges with JetIntelligence are designed to work flawlessly with this HP LaserJet Pro. Anti-fraud authentication helps protect your business from frustrating quality issues and costly reprints.
Wait less with an HP LaserJet Pro that prints faster than its predecessor – up to 23 pages per minute.Grab the documents you need and go. Print first pages in as fast as 7.3 seconds.Help save energy with HP Auto-On/Auto-Off Technology and Instant-on Technology. -
Connect this HP laser printer directly to your PC via the included Hi-Speed USB 2.0 port. -
Produce sharp text, bold blacks, and crisp graphics with precision black toner.Track toner levels with print gauge technology and produce the most prints possible.Quickly replace your cartridges, using auto seal removal and easy-open packaging.
- HP LaserJet Pro M102a - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- 4.7 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 22 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Interface
- USB 2.0
- Processor
- 600 MHz
- RAM Installed (Max)
- 128 MB (128 MB)
- Language Simulation
- PCLm, URF, PWG
- Media Type
- Envelopes, labels, plain paper, photo paper, card stock, vellum paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet input tray
- Monthly Duty Cycle (max)
- 10000 pages
- Recommended Monthly Volume
- 150 - 1500 pages
- System Requirements
- Microsoft Windows Vista (32-bit versions), Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
- Environmental Standards
- EPEAT Silver
- 36.47 cm x 24.73 cm x 19.06 cm
- Printer Type
- Personal printer - laser - monochrome
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 1200 dpi
- First Print Out Time B/W
- 7.3 sec
- PCLm, URF, PWG
- Media Handling
- Processor
- 600 MHz
RAM
- 128 MB / 128 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 76.2 x 127 mm
- Media Weight
- 60 g/m² - 163 g/m²
- 150 sheets
- Max Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 10000 pages
- 150 - 1500 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 380 watt
- Power Consumption Stand by
- 1.7 watt
- Power Consumption Sleep
- 0.5 watt
- Software Included
- Drivers & Utilities
- OS Required
- EPEAT Compliant
- EPEAT Silver
- Blue Angel
- ENERGY STAR
- 15 °C
- 32.5 °C
- 30 - 70% (non-condensing)
- Sound Emission (Operating)
- 51 dBA
- 36.47 cm
- 24.73 cm
- 19.06 cm
- 4.7 kg
- Width (Shipping)
- 39.7 cm
- Depth (Shipping)
- 24.7 cm
- Height (Shipping)
- 29.8 cm
- Weight (Shipping)
- 6.6 kg
Ink (3)
HP 17A Black original LaserJet toner cartridge | In Stock | £57.80 |
HP 19A Original LaserJet Imaging Drum | In Stock | £65.18 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £16.62 |
