HP LaserJet Pro M102a
Quicklinx: CBK8WS00 Mfr#: G3Q34A#B19
Keep things simple with an affordable HP LaserJet Pro powered by JetIntelligence Toner cartridges. Produce consistent, professional documents from a compact laser printer designed for efficiency.
Designed for efficiency
Help save energy. This efficient HP LaserJet Pro printer delivers documents quickly while helping to keep energy costs low, so you save resources.
Mobile printing made simple with the HP LaserJet Pro M102w
No network, no problem. Easily print from your laptop or PC, using a USB cable.
HP quality – print after print
Count on consistent results – Original HP Toner cartridges with JetIntelligence are designed to work flawlessly with this HP LaserJet Pro. Anti-fraud authentication helps protect your business from frustrating quality issues and costly reprints.
  • Designed for efficiency
    Wait less with an HP LaserJet Pro that prints faster than its predecessor – up to 23 pages per minute.Grab the documents you need and go. Print first pages in as fast as 7.3 seconds.Help save energy with HP Auto-On/Auto-Off Technology and Instant-on Technology.
  • Mobile printing made simple with the HP LaserJet Pro M102w
    Connect this HP laser printer directly to your PC via the included Hi-Speed USB 2.0 port.
  • HP quality – print after print
    Produce sharp text, bold blacks, and crisp graphics with precision black toner.Track toner levels with print gauge technology and produce the most prints possible.Quickly replace your cartridges, using auto seal removal and easy-open packaging.
HP LaserJet Pro M102a - printer - B/W - laser
Printer Type
Personal printer - laser - B/W
4.7 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 22 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
USB 2.0
600 MHz
RAM Installed (Max)
128 MB (128 MB)
Language Simulation
PCLm, URF, PWG
Media Type
Envelopes, labels, plain paper, photo paper, card stock, vellum paper
Total Media Capacity
150 sheets
Media Handling
150-sheet input tray
Monthly Duty Cycle (max)
10000 pages
Recommended Monthly Volume
150 - 1500 pages
Microsoft Windows Vista (32-bit versions), Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
Environmental Standards
EPEAT Silver
36.47 cm x 24.73 cm x 19.06 cm
Printer Type
Personal printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB 2.0
1200 dpi
First Print Out Time B/W
7.3 sec
Language Simulation
PCLm, URF, PWG
Media Handling
600 MHz
RAM
RAM Installed (Max)
128 MB / 128 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 76.2 x 127 mm
Media Weight
60 g/m² - 163 g/m²
150 sheets
Max Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Duty Cycle
10000 pages
150 - 1500 pages
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 700 pages
Power supply - internal
Frequency Required
50/60 Hz
380 watt
Power Consumption Stand by
1.7 watt
Power Consumption Sleep
0.5 watt
Software Included
Drivers & Utilities
EPEAT Compliant
EPEAT Silver
Blue Angel
ENERGY STAR
15 °C
32.5 °C
30 - 70% (non-condensing)
Sound Emission (Operating)
51 dBA
36.47 cm
24.73 cm
19.06 cm
4.7 kg
Width (Shipping)
39.7 cm
Depth (Shipping)
24.7 cm
Height (Shipping)
29.8 cm
Weight (Shipping)
6.6 kg
Ink (3)
CBK8 HP 17A Black original LaserJet toner cartridge In Stock £58.36
CBK8 HP 19A Original LaserJet Imaging Drum In Stock £65.77
CBK8 HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.72
Other bundles (2)
CBK8 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £33.60
CBK8 HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment for LaserJet 1018s In Stock £27.99
