Enhance documents with colour – and create marketing materials in-house – while keeping black printing costs low. HP's smallest colour laser printer is also one of the planet's most energy efficient. Easy-to-use features keep you productive.
Affordable, high-quality colour
Save money, save space: HP's lowest-priced colour laser printer is also one of the world's smallest.Print documents affordably. Get the same black cost per page as a black-and-white HP LaserJet printer.Ensure professional, accurate results with bold text, smooth colour and sharp images with HP ImageREt 2400.Print high-quality documents, using Original HP LaserJet toner cartridges with ColorSphere toner. -
Stay on task with fast setup and easy maintenance
Original HP cartridges are simple to install and easy to replace.Make maintenance easy with Original HP cartridges and a printer designed for lasting performance.Confirm your cartridge is Original HP for reliable performance, using HP Cartridge Authentication software. -
Reduce your environmental impact
One of the most energy-efficient colour laser printers on the planet.Conserve resources with HP's smallest colour laser printer.Conserve energy with Instant-on Technology, and save even more with HP Auto-On/Auto-Off Technology.Get free and easy recycling – cartridges returned through HP Planet Partners are recycled responsibly. -
Create and print your own marketing materials
Design marketing materials and get ideas for your printed projects from HP Creative Studio for Business.Print on a wide range of media – from 7.6 x 12.7 cm to 21.5 x 35.5 cm.Achieve great results – pre-configured shortcuts optimize output quality based on the media selected.Easily adjust spot colours and apply them throughout a document with basic colour-match settings.
- HP Color LaserJet Pro CP1025 - printer - colour - laser
- Printer Type
- Personal printer - laser - colour
- 12.1 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 16 ppm - black normal - A4 (210 x 297 mm) , Up to 4 ppm - colour normal - A4 (210 x 297 mm) , Up to 17 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 4 ppm - colour - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Max Resolution (Colour)
- 600 x 600 dpi
- Image Enhancement Technology
- HP ImageREt 2400
- Interface
- USB 2.0
- Processor
- 264 MHz
- RAM Installed (Max)
- 8 MB (8 MB) - SDRAM
- Flash Memory Installed (Max)
- 128 MB (128 MB)
- Media Type
- Envelopes, transparencies, labels, plain paper, photo paper, cards, bond paper, recycled paper, glossy paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet input tray
- Monthly Duty Cycle (max)
- 15000 pages
- Recommended Monthly Volume
- 200 - 850 pages
- System Requirements
- SunSoft Solaris 8, SunSoft Solaris 9, Microsoft Windows XP SP2 or later, HP-UX 11, Red Hat Fedora Core 9, Red Hat Fedora Core 10, Ubuntu 8.10, Ubuntu 9.04, SuSE Linux 11, Apple MacOS X 10.6, Debian GNU/Linux 5.0, Red Hat Enterprise Linux 5, Apple MacOS X 10.5, Microsoft Windows Server 2003 SP3 or later, SuSE Linux 10.3, Linux Linpus 9.4, Ubuntu 8.04, Microsoft Windows Vista (32/64 bits), Ubuntu 9.10, Red Hat Fedora Core 11, Red Hat Fedora Core 12, Debian GNU/Linux 5.0.1, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple MacOS X Lion 10.7, Linux Linpus 9.5, SuSE Linux 11.1, SuSE Linux 11.2, Ubuntu 8.04.1, Ubuntu 8.04.2, Debian GNU/Linux 5.0.2, Debian GNU/Linux 5.0.3
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 39.96 cm x 40.21 cm x 25.15 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 600 x 600 dpi
- 600 x 600 dpi
- HP ImageREt 2400
- First Print Out Time B/W
- 15.5 sec
- First Print Out Time Colour
- 27.5 sec
- Media Handling
- Processor
- 264 MHz
RAM
- 8 MB / 8 MB (max)
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 128 MB (installed) / 128 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), 76 x 127 mm
- Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets
- Max Media Capacity
- 150 sheets
- Output Trays Capacity
- 50 sheets
Duty Cycle
- 15000 pages
- 200 - 850 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 500 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
- UL, cUL, EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EMC, IEC 60950-1, EN 60950-1, IEC 60825-1, FCC CFR47 Part 15 B, EN 60825-1
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 295 Watt
- Power Consumption Stand by
- 8 Watt
- Power Consumption Sleep
- 3.1 Watt
- OS Required
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- Limited warranty - 1 year
- 15 °C
- 32.5 °C
- 10 - 80%
- Sound Emission (Operating)
- 49 dBA
- 39.96 cm
- 40.21 cm
- 25.15 cm
- 12.1 kg
- Width (Shipping)
- 49.8 cm
- Depth (Shipping)
- 29.8 cm
- Height (Shipping)
- 38.7 cm
- Weight (Shipping)
- 13.4 kg
