HP LaserJet Pro 4002dwe Printer
Quicklinx: H378WS00 Mfr#: 2Z606E#B19
This modern printer is built for maximum productivity with fast speeds and reliable hardware, delivering effortless everyday use so you can focus more on your business. And with HP+, printers have never been easier to manage and use from anywhere.
This is an HP+ printer. It requires an HP account, connection to the internet, and exclusive use of Original HP Toner cartridges for the life of the printer. More at:
  • Large workteam solution
    Support your dynamic workteam with this high-speed, multi-feature printer, ideal for up to 10 users.
  • Blazing fast speed
    Step up your workflow with blazing fast speed to meet high-demand environments.
  • Simple shortcuts
    Do more in fewer steps. Simple shortcuts allow your employees to complete common tasks with just a touch.
  • Set up. Invite users. And done
    Guided, cloud-based setup makes it easy to configure new printers and onboard users from any location.
  • Control at your fingertips
    Smart Admin Dashboard monitors usage and control settings across multiple printers, in multiple locations.
  • HP Smart
    Get productivity in the palm of your hand. Print and save time with Shortcuts from HP Smart.
HP LaserJet Pro 4002dwe - printer - B/W - laser - with HP+
Printer Type
Workgroup printer - laser - B/W
Number of Users
Up to 10 users
8.22 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 40 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 42 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 63 ppm - black landscape - A5 (148 x 210 mm) , Up to 14 ppm - black portrait - A5 (148 x 210 mm) , Up to 36 ipm - duplex - ANSI A (Letter) (216 x 279 mm) , Up to 34 ipm - duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
4800 x 600 dpi
Image Enhancement Technology
HP ProRes 1200 / HP FastRes 1200
Automatic Duplexing
USB 2.0, Gigabit LAN, Bluetooth, Wi-Fi(n)
AirPrint Enabled
1.2 GHz
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF, URF, PWG
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, light-weight paper, preprinted paper, letterheaded paper, coloured paper
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet input tray
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Print server
Printer Features
Print from mobile device, Instant-on Technology, Mopria certified, Auto Power On, Auto Power Off, JetIntelligence Cartridge Technology, HP Instant Ink
AC 220-240 V
UNIX, Microsoft Windows Server, Microsoft Windows 7, Android, Apple iOS, Windows 10, Apple macOS 10.15, Citrix, Apple macOS 11.0, Apple macOS 12, Windows 11
38.1 cm x 35.7 cm x 21.6 cm
Printer Type
Workgroup printer - laser - monochrome
Number of Users
Up to 10 users
Printer
Print Speed
Built-in Devices
2 line monochrome LCD display
Wireless
AirPrint Enabled
4800 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.3 sec
Language Simulation
Fonts Included
84 x TrueType
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), B6 (125 x 176 mm), 197 x 273 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm
Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
Media Weight
60 g/m² - 200 g/m²
Media Weight (lbs)
16 lbs - 53 lbs
350 sheets
Media Feeders
Multi-purpose tray: 1 - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 46.6 lbs (max)) , Input tray: 1 - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² - (16 lbs (min) - 32 lbs (max)) , Output tray: 1 - 150 sheets
Max Media Capacity
900 sheets
Output Trays Capacity
150 sheets
Duty Cycle
80000 pages
750 - 4000 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 2, SNMP 3, IPP, HTTP, HTTPS, SLP, DHCP, IPv4, IPv6
Security Protocols & Features
SSL, Apple Bonjour, IPv6 support
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 2900 pages
EN 61000-4-12, EN 62479:2010, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, FCC CFR47 Part 15 B Class B, CISPR 32 Class B, EN 62368-1:2014, EN 60825-1:2014, EN 55032:2012 Class B, IEC 60825-1:2014, IEEE 802.3az, Mercury-free, IEC 62368-1: 2014, IPv6, EN 61000-3-2:2019, CISPR 35: 2016, EN 61000-3-3:2013+A1:2019, IEC 61000-3-2:2019, ICES-003 issue 7, EN 55035 Class B, IPv4
Power supply - internal
AC 220-240 V
Frequency Required
50/60 Hz
495 Watt
Power Consumption Stand by
5.5 Watt
Power Consumption Sleep
0.5 Watt
System Requirements Details
HD 2 GB
Environmental Standards
Blue Angel
ENERGY STAR
ENERGY STAR Version
3.0
10 °C
32.5 °C
10 - 80% RH
Sound Emission (Operating)
54 dBA
38.1 cm
35.7 cm
21.6 cm
8.22 kg
Width (Shipping)
44.3 cm
Depth (Shipping)
27.4 cm
Height (Shipping)
46.4 cm
Weight (Shipping)
10.5 kg
Ink (1)
H378 HP HP - Black - original - LaserJet - toner cartridge In Stock £84.64
Other bundles (1)
H378 HP 550 sheet paper tray for LaserJet Pro M402d, M402n, M402dn In Stock £98.06
