Get blazing fast printing speeds and easy management tools with LaserJet Pro.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Large workteam solution
Support your dynamic workteam with this high-speed printer, ideal for up to 10 users. -
HP Pro-class print speed
Step up your workflow. HP Pro-class print speed reaches up to 42 ppm to meet high-demand environments. -
HP Smart
Get productivity in the palm of your hand. Print and save time with Shortcuts from HP Smart. -
HP Web Jetadmin
Centralise your print management. HP Web Jetadmin makes it easy with its suite of features.
- HP LaserJet Pro 4002dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- Number of Users
- Up to 10 users
- 8.56 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 40 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 42 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 63 ppm - black landscape - A5 (148 x 210 mm) , Up to 14 ppm - black portrait - A5 (148 x 210 mm) , Up to 36 ipm - duplex - ANSI A (Letter) (216 x 279 mm) , Up to 34 ipm - duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 4800 x 600 dpi
- Image Enhancement Technology
- HP ProRes 1200 / HP FastRes 1200
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN
- AirPrint Enabled
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 6, PCL 5E, PDF, PostScript 3, PWG, URF
- Media Type
- Plain paper, envelopes, bond paper, coloured paper, labels, letterheaded paper, light-weight paper, preprinted paper, recycled paper
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet input tray
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Networking
- Print server
- Printer Features
- Instant-on Technology, JetIntelligence Cartridge Technology, Mopria certified, HP Instant Ink, print from mobile device, Auto Power Off, Auto Power On
- Power
- AC 220-240 V
- System Requirements
- Microsoft Windows Server, Windows 11, Windows 10, Microsoft Windows 7, Android, Apple iOS, Apple macOS 10.15, Apple macOS 11.0, Apple macOS 12, UNIX, Citrix
- 1-year warranty
- 38.1 cm x 35.7 cm x 21.6 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Number of Users
- Up to 10 users
- Localisation
Printer
- Print Speed
- Built-in Devices
- 2 line monochrome LCD display
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 4800 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.3 sec
- Fonts Included
- 84 x TrueType
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 256 MB / 256 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 184 x 260 mm, 195 x 270 mm, 197 x 273 mm, B5 (176 x 250 mm), B6 (125 x 176 mm), JIS B5 (182 x 257 mm), JIS B6 (128 x 182 mm), Oficio (216 x 343 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- Media Weight (lbs)
- 16 lbs - 53 lbs
- 350 sheets
- Media Feeders
- Multi-purpose tray: 1 - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 46.6 lbs (max)) , Input tray: 1 - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² - (16 lbs (min) - 32 lbs (max)) , Output tray: 1 - 150 sheets
- Max Media Capacity
- 900 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 80000 pages
- 750 - 4000 pages
- Networking
- Print server
- Remote Management Protocol
- HTTP, HTTPS, SNMP 1, SNMP 2, SNMP 3, IPv6, IPv4, IPP, DHCP, SLP
- Apple Bonjour, IPv6 support, SSL
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 2900 pages
- CISPR 32 Class B, EN 55032:2012 Class B, CISPR 35: 2016, EN 55035 Class B, IEC 61000-3-2:2019, EN 61000-3-2:2019, EN 61000-3-3:2013+A1:2019, EN 61000-4-12, FCC CFR47 Part 15 B Class B, ICES-003 issue 7, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62368-1: 2014, EN 62368-1:2014, IEC 60825-1:2014, EN 60825-1:2014, IEC 62479:2010, EN 62479:2010, Mercury-free, IEEE 802.3az, IPv6, IPv4
- Power Device
- Power supply - internal
- Voltage Required
- AC 220-240 V
- Frequency Required
- 50/60 Hz
- 495 Watt
- Power Consumption Stand by
- 5.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- System Requirements Details
- HD 2 GB
Environmental Standards
- Blue Angel
- ENERGY STAR
- ENERGY STAR Version
- 3.0
- Limited warranty - 1 year
- 10 °C
- 32.5 °C
- 10 - 80% RH
- Sound Emission (Operating)
- 54 dBA
- 38.1 cm
- 35.7 cm
- 21.6 cm
- 8.56 kg
- Width (Shipping)
- 44.3 cm
- Depth (Shipping)
- 27.4 cm
- Height (Shipping)
- 46.4 cm
- Weight (Shipping)
- 10.5 kg
Ink (2)
HP HP - Black - original - LaserJet - toner cartridge | In Stock | £87.04 |
HP 149X - high capacity - black - original - LaserJet - toner cartridge | In Stock | £173.40 |
Other bundles (1)
HP 550 sheet paper tray for LaserJet Pro M402d, M402n, M402dn | In Stock | £98.55 |
