HP LaserJet Pro 400 M401a Mono Laser Printer
Quicklinx: 8268WS00 Mfr#: CF270A#B19
Do more with your workday. Set up anywhere in the office using built-in wireless networking and share printing resources on a network. Print on the go with mobile printing options. Use business apps to access and print from the web.
  • Stay productive and boost business with wireless networking and impressive mobility
    Set up and share anywhere in the office with wireless connectivity,. Configure networking fast,.Print from virtually anywhere with HP ePrint,. Print wirelessly from your iPad , iPhone , and iPod touch with AirPrint .Send files from a mobile device directly to your printer using HP wireless direct printing,.
  • Experience web-connected ease of use
    Use business apps and the 8.89 cm (3.5-inch) colour touchscreen to access and print from the web,, e.g. with Google Docs 2012 Google.Manage workflow with intuitive features right on the printer. A convenient USB port enables printing directly from a flash drive.Easily control your print environment and save IT time and costs – HP Web Jetadmin helps you monitor equipment and increase uptime.
  • Enjoy professional-quality output for a great value
    Produce professional-quality business documents with bold, crisp text and sharp images.Get peace of mind with trusted HP LaserJet reliability and consistent print quality from the first to the last page.Save time with easy-to-install Original HP cartridges, and save money with optional high-capacity cartridges designed for frequent printing.Do more with a 300-sheet paper capacity, (800-sheets total with optional 500-sheet tray).
  • Reduce your environmental impact
    Save energy with HP Auto-On/Auto-Off Technology which turns your printer on when you need it and off when you don't.Reduce paper use by up to 50% with automatic two-sided printing.Easily recycle Original HP LaserJet toner cartridges through HP Planet Partners.Reduce packaging waste: Original HP toner cartridge HP 80A ships in the printer.
HP LaserJet Pro 400 M401a - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
10.1 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 33 ppm - black normal - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
USB
800 MHz
RAM Installed (Max)
128 MB (128 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 3000 pages
HP-UX 11i, Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Debian GNU/Linux 5.0, Microsoft Windows Vista (64-bit versions), Red Hat Enterprise Linux 5, Apple MacOS X 10.5, Linux Linpus 9.4, openSUSE 11.3, Ubuntu 10.04, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Red Hat Fedora 14, Apple MacOS X Lion 10.7, Debian Linux 6.x, Red Hat Fedora 15, Ubuntu 10.10, openSUSE 11.4, Ubuntu 11.04, Linux Linpus 9.5
Microsoft Certification
Compatible with Windows 7
1-year warranty
36.5 cm x 36.8 cm x 26.8 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB
1200 dpi
First Print Out Time B/W
8 sec
Language Simulation
Fonts Included
84 x TrueType
Media Handling
800 MHz
RAM
RAM Installed (Max)
128 MB / 128 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 76 x 127 mm
Media Weight
60 g/m² - 163 g/m²
300 sheets
Max Media Capacity
300 sheets
Output Trays Capacity
150 sheets
Duty Cycle
50000 pages
750 - 3000 pages
1 x USB 2.0
IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, GB 4943
Power supply - internal
Frequency Required
50 Hz
570 watt
Power Consumption Stand by / Sleep
6.2 watt
System Requirements Details
Windows 7/Vista - 1 GHz - RAM 1 GB - HD 400 MB , Windows XP SP2 - Pentium - 233 MHz - RAM 512 MB - HD 400 MB , MacOS X 10.5/10.6/10.7 - PowerPC G4 HD 500 MB
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
15 °C
32.5 °C
10 - 90% (non-condensing)
Sound Emission (Operating)
51 dBA
36.5 cm
36.8 cm
26.8 cm
10.1 kg
Width (Shipping)
48 cm
Depth (Shipping)
43 cm
Height (Shipping)
33 cm
Weight (Shipping)
13.3 kg
8268 HP 80A Black Original LaserJet Toner Cartridge In Stock £96.27
8268 HP 80X High Yield Black Original LaserJet Toner Cartridge In Stock £165.72
8268 HP 80X 2-pack High Yield Black Original LaserJet Toner Cartridges In Stock £333.07
