HP LaserJet Pro 300 M375nw Colour Laser Multifunction Printer
Quicklinx: 7XSTWS00 Mfr#: CE903A#B19
Boost productivity and gain efficiency: easily print, scan directly to email, copy and fax with a web-connected, colour laser MFP. Produce professional-quality, colour documents in-house and print from virtually anywhere with HP ePrint[1].
Make an impression with professional colour marketing materials created in-house.
Achieve crisp, detailed text and consistently smooth colour with HP ImageREt 3600 and Original HP LaserJet toner cartridges.
Design and produce colour marketing materials in-house on a range of media sizes from 8.9 x 12.7 cm (3.5 x 5 inches) to 21.6 x 35.6 cm (8.5 x 14 inches). Go to www.hp.com/create for tips and templates from HP.
Print black text affordably - at the same cost per page as a black-and-white HP LaserJet MFP[2].
Save money with high-capacity black print cartridges designed for frequent printing[3].
Print, copy, scan and fax with one efficient, networked HP LaserJet MFP.
Boost productivity and save time with impressive print speeds up to 18 ppm A4.
Conveniently locate the MFP anywhere in the office, using wireless connectivity[4].
Use built-in 10/100 Ethernet to share printing resources on a network and use the front-facing USB port to print from - and save scans to - a flash drive.
Install the MFP in only a few minutes: HP Smart Install makes it easy to quickly start printing from a PC or netbook, without a CD - just plug in and install[5].
Experience web-connected efficiency and expandability.
Use business apps and the 8.9 cm (3.5-inch) colour touchscreen to access, store and print information from the web[6].
Convert hard copies to digital files quickly and easily - scan to a USB drive, email or network folder[7].
Print from virtually anywhere with HP ePrint[1]. Print from smartphones directly to your printer using ePrint Wireless Direct printing[8] and print wirelessly from your iPad®, iPhone®, and iPod touch® with AirPrint™[9].
Proactively manage this MFP with HP Web Jetadmin.
Conserve resources with innovative energy-saving features.
Reduce energy use with HP Auto-On/Auto-Off Technology, which turns the printer on when you need it and off when you don't[10].
Save even more energy with Instant-on Technology, an innovative, quick-heating fuser system that warms rapidly and cools quickly[11].
Get centralised, easy access to custom, energy-saving options and printer settings with HP EcoSMART Console.
Take advantage of free, easy recycling - cartridges returned through HP Planet Partners are recycled responsibly[12].
[1] Requires an Internet connection to the printer. Feature works with any Internet- and email-capable device. Print times may vary. For a list of supported documents and image types, see www.hp.com/go/eprintcenter.
[2] Compared with HP LaserJet Pro M1536. Assuming customer is printing at least 30% of total pages in colour with content similar to the colour ISO/IEC 19798 test suite (www.iso.org/jtc1/sc28) and overall average job length of three pages. Yields established using ISO/IEC test standards. Actual yields and costs vary considerably depending on images printed, number of colour pages printed, and other factors.
[3] HP LaserJet 305X Black Toner Cartridge not included; please purchase separately.
[4] Wireless performance is dependent upon physical environment and distance from access point, and may be limited during active VPN connections.
[5] HP Smart Install works with Windows only.
[6] Requires a wireless access point and an Internet connection to the printer. Services may require registration. Availability varies by country, language, and agreements, and requires a firmware upgrade. For details, www.hp.com/go/eprintcenter.
[7] May require a firmware upgrade.
[8] Mobile device must be wireless-enabled. Printer must be HP ePrint-enabled. Feature may require driver or apps, available for download at www.hp.com/go/eprintcenter. Available only on the HP LaserJet Pro 300 color MFP M375nw.
[9] Supports iOS 4.2 devices (iPad, iPhone 4, iPhone 3GS, and 3rd and 4th generation iPod touch) that support multitasking. Works with HP ePrint-enabled printers and all-in-ones. AirPrint and iOS 4.2 devices require an 802.11 wireless network connection to the printer. Wireless performance is dependent upon physical environment and distance from the access point. AirPrint and the AirPrint Logo are trademarks of Apple Inc. iPad, iPhone and iPod touch are trademarks of Apple Inc., registered in the U.S. and other countries.
[10] HP Auto-On/Auto-Off capabilities subject to printer and settings.
[11] Compared with products that use traditional fusing.
[12] Programme availability varies. HP print cartridge return and recycling is currently available in more than 50 countries and territories around the world through the HP Planet Partners programme. For more information, or to request return envelopes and bulk collection boxes, visit www.hp.com/recycle
