Produce professional colour documents that help boost business. Print from virtually anywhere with HP ePrint. Use business apps to access and print from the web,. Locate the printer anywhere in the office, using wireless connectivity,.
Enjoy fast set up and easy, web-connected printing
Use business apps and the 8.9 cm (3.5-in) colour touchscreen to access and print from the web,.Use the colour touchscreen to preview and select the pictures that you want to print from your flash drive.Print directly from a flash drive using the easy-access USB port. -
Maintain the pace of business with mobile printing
Print from virtually anywhere with HP ePrint.Print wirelessly from your iPad , iPhone , and iPod touch with AirPrint .Send files from a mobile device directly to your printer – without a network – using HP wireless direct printing.Set up and share the printer anywhere in the office with wireless and built-in Ethernet connectivity,. -
Create high-impact, colour marketing materials
Get accurate colour with HP ImageREt 3600 and ColorSphere II toner. Optimise settings with HP EasyColor.Boost productivity with print speeds of up to 14 ppm. Reload the paper tray less often, thanks to the 150-sheet capacity.Create impressive colour marketing materials on a range of media, including HP specialty papers.Print affordably – get the same black cost per page as a black-only HP LaserJet printer. Save money with the high-capacity HP LaserJet 131X Black Toner Cartridge. -
Reduce your environmental impact
Reduce energy use with HP Auto-On/Auto-Off Technology which turns your printer on when you need it and off when you don't.Save energy and time with Instant-on Technology – start printing and get the first page out as fast as 19 seconds.Receive consistent results with Original HP LaserJet toner cartridges and reorder with HP SureSupply.Get free, easy recycling: toner cartridges returned through HP Planet Partners are recycled responsibly.
- HP LaserJet Pro 200 M251nw - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 18.8 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 14 ppm - black normal - A4 (210 x 297 mm) , Up to 14 ppm - colour normal - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Max Resolution (Colour)
- 600 x 600 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Interface
- USB, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Preview Screen Size
- 3.5"
- Processor
- 750 MHz
- RAM Installed (Max)
- 128 MB (128 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6
- Media Type
- Envelopes, transparencies, labels, plain paper, photo paper, heavy-weight paper, cards, bond paper, recycled paper, glossy paper
- Total Media Capacity
- 150 sheets
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 1500 pages
- Networking
- Print server - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- SunSoft Solaris 8, SunSoft Solaris 9, Microsoft Windows XP SP2 or later, HP-UX 11, Red Hat Fedora Core 9, Red Hat Fedora Core 10, Ubuntu 8.10, Ubuntu 9.04, SuSE Linux 11, Apple MacOS X 10.6, Debian GNU/Linux 5.0, Red Hat Enterprise Linux 5, Apple MacOS X 10.5, Microsoft Windows Server 2003 SP3 or later, SuSE Linux 10.3, Linux Linpus 9.4, Ubuntu 8.04, Microsoft Windows Vista (32/64 bits), Ubuntu 9.10, Red Hat Fedora Core 11, Red Hat Fedora Core 12, Debian GNU/Linux 5.0.1, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple MacOS X Lion 10.7, Linux Linpus 9.5, SuSE Linux 11.1, SuSE Linux 11.2, Ubuntu 8.04.1, Ubuntu 8.04.2, Debian GNU/Linux 5.0.2, Debian GNU/Linux 5.0.3
- Environmental Standards
- EPEAT Silver
- 40.5 cm x 45.3 cm x 26.5 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- Touch screen
- 3.5"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 600 x 600 dpi
- 600 x 600 dpi
- HP ImageREt 3600
- PostScript Support
- Standard
- First Print Out Time B/W
- 18.5 sec
- First Print Out Time Colour
- 19 sec
- Fonts Included
- 84 x TrueType
- Processor
- 750 MHz
RAM
- 128 MB / 128 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 76.2 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets - Legal (216 x 356 mm)
- Max Media Capacity
- 150 sheets
- Output Trays Capacity
- 125 sheets
Duty Cycle
- 30000 pages
- 250 - 1500 pages
- Networking
- Print server
- Data Link Protocol
- TCP/IP, LPR/LPD, ARP, BOOTP, DHCP, Bonjour, SLP
- Remote Management Protocol
- SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP
- SSL, TLS, WPA, WPA2, 802.1x, ARP
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Connections
- 1 x USB 2.0 ¦ 1 x LAN - RJ-45
- Cables Included
- 1 x USB cable
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages , 1 x toner cartridge (cyan) - up to 700 pages , 1 x toner cartridge (magenta) - up to 700 pages , 1 x toner cartridge (yellow) - up to 700 pages
- CISPR 22 Class B, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EMC, IEC 60950-1, EN 60950-1, FCC CFR47, IEC 60825-1, EN 60825-1, IPv6 Ready
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 315 Watt
- Power Consumption Stand by / Sleep
- 15.2 Watt
- Software Included
- Driver, HP ePrint
- OS Required
- System Requirements Details
- Windows 7/Vista - 1 GHz - RAM 1 GB - HD 200 MB , Windows XP SP2 - Pentium - 233 MHz - RAM 512 MB - HD 200 MB , MacOS X 10.5/10.6/10.7 - PowerPC G4 RAM 256 MB - HD 300 MB
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- 15 °C
- 33 °C
- 10 - 80%
- Sound Emission (Operating)
- 47 dBA
- 40.5 cm
- 45.3 cm
- 26.5 cm
- 18.8 kg
- Width (Shipping)
- 55 cm
- Depth (Shipping)
- 50 cm
- Height (Shipping)
- 33.3 cm
- Weight (Shipping)
- 22.8 kg
