Produce professional-quality colour and easily print, scan and copy, using HP's smallest colour laser MFP. Print from mobile devices, using HP ePrint[1] or WiFi Direct printing[2], and get quick-and-easy setup so you can start printing faster.
Ideal for home office and small-business customers who want a low-priced, compact colour laser MFP, wireless and Ethernet connectivity[6], mobile printing options, and features that help conserve energy.
Make an impact with professional-quality colour from HP's smallest colour MFP.
-Print, scan and copy outstanding colour documents with this low-priced colour laser MFP.
-Easily enhance the quality of your copied images, text and graphics with automatic copy optimisation.
-Print professional colour: HP ImageREt 2400 delivers crisp detail and consistent colour. Use Original HP cartridges with HP ColorSphere toner to maximise the impact of marketing and business documents.
-Print black text affordably - at the same cost per page as a black-and-white HP LaserJet printer[3].
Mobile printing with HP ePrint[1], WiFi Direct [2], wireless printing [4], and quick, easy set-up.
-Stay productive on the go using HP ePrint[1], and print from wireless-enabled mobile devices directly to your printer[2].
-Install your MFP in only a few minutes using HP Smart Install[5], and easily print and share with built-in wireless and Ethernet connectivity[6].
-Easily produce one-sided copies of two-sided IDs using ID copy. Scan instantly to a PC, email and more.
-Confirm your cartridge is Original HP to ensure superior performance and reliability, using HP Toner Cartridge Authentication[7].
Get the versatility you need with this reliable MFP.
-Print on a wide range of paper sizes from 3.5 x 5 ins (8.9 x 12.7 cm) to 8.5 x 14 ins (21.6 x 35.6 cm).
-Achieve great results: print everyday documents, envelopes, cardstock, labels and images that look professional. Pre-configured shortcuts automatically optimise output quality based on the media selected.
-You can easily scan to a variety of network folders, or to any email address using your PC.
-Use the 35-page document feeder for unattended copying and printing of documents with multiple pages.
Reduce your environmental impact and conserve resources.
-Achieve up to 50% energy savings, using an HP LaserJet with HP Auto-Off Technology[8] which automatically senses your printing activity, turning your printer off when you don't need it.
-Reduce energy use with Instant-on Technology and Instant-on Copy[9].
-Take advantage of free, easy recycling - cartridges returned through HP Planet Partners are recycled responsibly[10].
-Save space and reduce packaging waste compared with larger-sized products - use a compact colour laser MFP.
[1] HP ePrint requires an internet connection to the printer. Feature works with any internet- and email-capable device. Print times may vary. Available on the HP LaserJet Pro 100 color MFP M175nw only. For a list of supported documents and image types, see www.hp.com/go/eprintcenter.
[2] Available as of September 2011. WiFi Direct printing requires a wireless capable device or mobile device and is available on the HP LaserJet Pro 100 color MFP M175nw only. Mobile device must be wireless-enabled and within wireless range of the printer. Feature may require the download of driver or apps to mobile device, available at www.hp.com/go/eprintercenter.
[3] Compared with HP LaserJet Pro P1566/ P1606dn printer (single function) and HP LaserJet Pro M1536dnf MFP. Assuming customer is printing at least 30 percent of total pages in colour with content similar to the colour ISO/IEC 19798 test suite (www.iso.org/jtc1/sc28) and overall average job length of three pages. Yields established using ISO/IEC test standards. Actual yields and costs vary considerably depending on images printed, number of colour pages printed, and other factors.
[4] Built-in wireless is available on the HP LaserJet Pro 100 color MFP M175nw only. Wireless performance is dependent upon physical environment and distance from access point, and may be limited during active VPN connections.
[5] HP Smart Install works with Windows only.
[6] Built-in Ethernet networking and wireless and Internet connectivity are available on the HP LaserJet Pro 100 color MFP M175nw only.
[7] Compatible with a range of HP LaserJet printers and MFPs. For more information, see, www.hp.com/go/learnaboutsupplies.
[8] HP Auto-Off capabilities subject to printer settings. Compares energy consumption of HP LaserJets with HP Auto-Off Technology to top competing models based on market share as of September 2010. Energy consumption based on HP internal testing using the ENERGY STARĀ® programme's Typical Electricity Consumption (TEC) method or TEC value found at energystar.gov./eu-energystar.org using greatest TEC value reported. Actual power usage may vary.
[9] Compared with products that use traditional fusing and cold cathode fluorescent lamp (CCFL) copying.
[10] Programme availability varies. HP print cartridge return and recycling is currently available in more than 50 countries and territories around the world through the HP Planet Partners programme. For more information, or to request return envelopes and bulk collection boxes, visit www.hp.com/recycle.
